Windows 8, Visual Studio Express 2013, build error
MarsaPalas
Post by MarsaPalas »
I was following two build tutorials
1) https://gitlab.inria.fr/openvibe/sdk/-/ ... INSTALL.md
2) http://openvibe.inria.fr/build-instructions/
but I keep getting errors at the very beginning when I try to install dependencies with script windows-install-dependencies-all-x64.cmd (that is located in script folder of a repository)
The first part of an error message is this:
===Installing dependencies===
InstallDeps : - Credentials or https://extranet.mensiatech.com/dependencies are not specified, can
not download dependency.
At C:\Users\milana\repos\sdk\scripts\windows-get-dependencies.ps1:254 char:2
+ InstallDeps $arch $dir $version
+ CategoryInfo : NotSpecified: (:) [Write-Error], WriteErrorException
+ FullyQualifiedErrorId : Microsoft.PowerShell.Commands.WriteErrorException,InstallDeps
InstallDeps : - They have to be set through environment variables: PROXYPASS and URL.
I realize it maybe has to do with PROXYPASS variable, since I haven't set it at all. I'm not sure what to put there, so I've just cleared it.
I am using Windows 8 in a VirtualBox.
If anybody has a clue what to try or do next, I would appreciate it very much!
Re: Windows 8, Visual Studio Express 2013, build error
Post by Thomas »
Hi MarsaPalas,
I dont have a windows machine at hand to try it, but I do have a suggestion:
Instead of running windows-install-dependencies-all-x64.cmd (from C:\Users\milana\repos\sdk\scripts\), can you try to run C:\Users\milana\repos\install_dependencies.cmd (This script should set all the variables needed).
