Ubuntu 20.04 build Error
Post Reply
Mike_qp
Post by Mike_qp »
Hi,
I'm trying to build OV on Ubuntu 20.04 (Focal Fossa), as i saw on the forum that it was feasible.
After dealing with install-dependencies issues (had to manually install git), i'v got somme errors during build.sh installation :
Code: Select all
CMake Deprecation Warning at CMakeLists.txt:3 (cmake_policy):
  The OLD behavior for policy CMP0026 will be removed from a future version
  of CMake.
  The cmake-policies(7) manual explains that the OLD behaviors of all
  policies are deprecated and that a policy should be set to OLD only under
  specific short-term circumstances.  Projects should be ported to the NEW
  behavior and not rely on setting a policy to OLD.
CMake Deprecation Warning at CMakeLists.txt:5 (cmake_policy):
  The OLD behavior for policy CMP0042 will be removed from a future version
  of CMake.
CMake Deprecation Warning at CMakeLists.txt:6 (cmake_policy):
  The OLD behavior for policy CMP0043 will be removed from a future version
  of CMake.
CMake Deprecation Warning at CMakeLists.txt:7 (cmake_policy):
  The OLD behavior for policy CMP0045 will be removed from a future version
  of CMake.
-- META OPTIONS :
--   Flag_VerboseOutput = 'OFF'
--   OV_DISPLAY_ERROR_LOCATION = 'ON'
--   OV_PACKAGE = 'OFF'
--   BUILD_VALIDATION_TEST = 'ON'
--   BUILD_UNIT_TEST = 'ON'
--   BUILD_DOCUMENTATION = 'OFF'
-- Found Eigen
-- Found Lua library
-- Found TinyXML2 library
-- Found VRPN library
CMake Warning at CMake/Utilities.cmake:65 (message):
  No tags found, set version to 0.0.0
Call Stack (most recent call first):
  sdk/CMakeLists.txt:10 (set_version)
-- BUILDING VERSION OpenViBE SDK: 0.0.0.0 Branch : unknown~0
-- Appending compilation flags...
-- Compilation flags used at source root:
--   COMPILE_DEFINITIONS = 'OV_CMAKE_PATH_ROOT="/home/michael/Documents/openvibe-3.4.0-src/dist/Release";OV_CMAKE_PATH_BIN="/home/michael/Documents/openvibe-3.4.0-src/dist/Release/bin";OV_CMAKE_PATH_LIB="/home/michael/Documents/openvibe-3.4.0-src/dist/Release/lib";OV_CMAKE_PATH_DATA="/home/michael/Documents/openvibe-3.4.0-src/dist/Release/share/openvibe";OV_CONFIG_SUBDIR="OpenVIBE-3.4.0";OV_PROJECT_NAME="OpenVIBE_SDK";OV_VERSION_MAJOR="0";OV_VERSION_MINOR="0";OV_VERSION_PATCH="0"'
--   CMAKE_CXX_FLAGS = ' -fopenmp -Wall -msse2'
--   CMAKE_CXX_FLAGS_RELEASE = '-O3 -DNDEBUG'
--   CMAKE_CXX_FLAGS_DEBUG = '-g'
--   Found dl...
--   Found pthread...
--   Found dl...
--   Found pthread...
-- Found Python3: /usr/bin/python3.8 (found version "3.8.10") found components: Interpreter Development
-- Found Python3 at /usr/bin/python3.8
  designer/CMakeLists.txt:31 (set_version)
-- BUILDING VERSION Designer: 0.0.0.0 Branch : unknown~0. Based on OpenViBE SDK: 0.0.0.0
-- Building OpenViBE Designer [openvibe] Version : 0.0.0 unknown~0
-- Now building openvibe-plugins-designer-advanced-vis  (unknown~0)
-- Now building openvibe-plugins-designer-simple-vis  (unknown~0)
-- Now building mensia-advanced-visualization 3.4.0 (unknown~0)
-- Now building openvibe-lib-adv-viz-test-renderer 3.4.0 (unknown/0)
-- Now building openvibe-visualization-toolkit 3.4.0 (unknown~0)
--   COMPILE_DEFINITIONS = 'OV_CMAKE_PATH_ROOT="/home/michael/Documents/openvibe-3.4.0-src/dist/Release";OV_CMAKE_PATH_BIN="/home/michael/Documents/openvibe-3.4.0-src/dist/Release/bin";OV_CMAKE_PATH_LIB="/home/michael/Documents/openvibe-3.4.0-src/dist/Release/lib";OV_CMAKE_PATH_DATA="/home/michael/Documents/openvibe-3.4.0-src/dist/Release/share/openvibe";OV_PROJECT_NAME="Extras";OV_VERSION_MAJOR="3";OV_VERSION_MINOR="4";OV_VERSION_PATCH="0";OV_CONFIG_SUBDIR="OpenVIBE-3.4.0";TARGET_OS_Linux_Debian;TARGET_ARCHITECTURE_x64;TARGET_OS_Linux;TARGET_COMPILER_GCC'
-- Note: Disabling Matlab plugin compilation by default
--   Found OpenViBE module Geometry...        /home/michael/Documents/openvibe-3.4.0-src/extras/modules/geometry/include
--   Found liblsl...
--     [  OK  ] Third party lib /home/michael/Documents/openvibe-3.4.0-src/dependencies/lib/liblsl.so
--   Found GTK+...
--     [  OK  ] Third party lib /usr/lib/x86_64-linux-gnu/libgtk-x11-2.0.so
--     [  OK  ] Third party lib /usr/lib/x86_64-linux-gnu/libgdk-x11-2.0.so
--     [  OK  ] Third party lib /usr/lib/x86_64-linux-gnu/libpangocairo-1.0.so
--     [  OK  ] Third party lib /usr/lib/x86_64-linux-gnu/libatk-1.0.so
--     [  OK  ] Third party lib /usr/lib/x86_64-linux-gnu/libcairo.so
--     [  OK  ] Third party lib /usr/lib/x86_64-linux-gnu/libgdk_pixbuf-2.0.so
--     [  OK  ] Third party lib /usr/lib/x86_64-linux-gnu/libgio-2.0.so
--     [  OK  ] Third party lib /usr/lib/x86_64-linux-gnu/libpangoft2-1.0.so
--     [  OK  ] Third party lib /usr/lib/x86_64-linux-gnu/libpango-1.0.so
--     [  OK  ] Third party lib /usr/lib/x86_64-linux-gnu/libgobject-2.0.so
--     [  OK  ] Third party lib /usr/lib/x86_64-linux-gnu/libharfbuzz.so
--     [  OK  ] Third party lib /usr/lib/x86_64-linux-gnu/libfontconfig.so
--     [  OK  ] Third party lib /usr/lib/x86_64-linux-gnu/libfreetype.so
--     [  OK  ] Third party lib /usr/lib/x86_64-linux-gnu/libgthread-2.0.so
--     [  OK  ] Third party lib /usr/lib/x86_64-linux-gnu/libglib-2.0.so
--     [  OK  ] Third party lib /usr/lib/x86_64-linux-gnu/libz.so
-- Note: /home/michael/Documents/openvibe-3.4.0-src/extras/plugins/processing/matlab has been skipped by setting SKIP_PLUGINS_PROCESSING_MATLAB
--   Found fftw3 includes...
--     [  OK  ] Third party lib /usr/lib/x86_64-linux-gnu/libfftw3.so
--   Found OpenViBE module TCPTagging...      /home/michael/Documents/openvibe-3.4.0-src/extras/modules/tcptagging/include
--   Found ALUT...
--     [  OK  ] Third party lib /usr/lib/x86_64-linux-gnu/libalut.so
--     [  OK  ] Third party lib /usr/lib/x86_64-linux-gnu/libopenal.so
--   Found VORBIS...
--     [  OK  ] Third party lib /usr/lib/x86_64-linux-gnu/libvorbisfile.so
--   Found X11...
--     [  OK  ] Third party lib /usr/lib/x86_64-linux-gnu/libX11.so
--   Found pthread...
--   Found pthread...
--   Found openvibe-contributions...
--   FAILED to find Emotiv API (optional driver)
--   FAILED to find MindMedia NeXus device dll (optional driver)
--   FAILED to find MCS device SDK (optional driver)
--   FAILED to find Mensia Acquisition driver (optional driver)
--   FAILED to find Micromed device dlls (optional driver)
--   Skipped Enobio3G, its work in progress.
--   Skipped ThinkGear API for Neurosky MindSet, only available on windows.
--   FAILED to find TMSi device dll (optional driver)
--   Found rt...
--   FAILED to find EEGO API (optional driver) - cmake looked in '/home/michael/Documents/openvibe-3.4.0-src/dependencies', skipping EEGO.
--   FAILED to find gtec gMobiLabPlusAPI... (optional driver)
--    : If it should be found, see that 'gmobilabapi.so' link exists on the fs, with no numeric suffixes in the filename.
--    : e.g. do 'cd /usr/lib/  ln -s libgmobilabplusapi.so.1.12 libgmobilabplusapi.so'
--   FAILED to find gtec gUSBAmpAPI Linux... (optional)
--    : If it should be found, see that 'libgusbampapi.so.1.14' link exists on the fs, with no further nemeric suffixes in the filename.
--    : e.g. do 'cd /usr/lib/  ln -s libgusbampapi.so.1.14'. See gtec-bcilab/README for details.
--   FAILED to find Mitsar device dll (optional driver)
--   Gtec Unicorn device API (optional driver): No Linux support
--   Found OpenGL...
--     [  OK  ] Third party lib /usr/lib/x86_64-linux-gnu/libGLU.so
--     [  OK  ] Third party lib /usr/lib/x86_64-linux-gnu/libGL.so
--   Found rt...
-- Found Python3: /usr/lib/x86_64-linux-gnu/libpython3.8.so (found version "3.8") found components: Development
--   Found Python 3 at /usr/lib/x86_64-linux-gnu/libpython3.8.so
-- Note: /home/michael/Documents/openvibe-3.4.0-src/extras/contrib/plugins/processing/python2 has been skipped by setting SKIP_CONTRIB_PLUGINS_PROCESSING_PYTHON2
--   Found it++...
--     [  OK  ] Third party lib /usr/lib/x86_64-linux-gnu/libitpp.so
-- Configuring done
-- Generating done
-- Build files have been written to: /home/michael/Documents/openvibe-3.4.0-src/build
[1/744] Linking CXX shared library sdk/modules/fs/libopenvibe-module-fs.so.3.4.0
FAILED: sdk/modules/fs/libopenvibe-module-fs.so.3.4.0
: && /usr/bin/c++ -fPIC -fopenmp -Wall -msse2 -O3 -DNDEBUG   -shared -Wl,-soname,libopenvibe-module-fs.so.3 -o sdk/modules/fs/libopenvibe-module-fs.so.3.4.0 sdk/modules/fs/CMakeFiles/openvibe-module-fs.dir/src/Files.cpp.o sdk/modules/fs/CMakeFiles/openvibe-module-fs.dir/src/IEntryEnumerator.cpp.o  /usr/lib/x86_64-linux-gnu/libboost_filesystem.a && :
/usr/bin/ld: /usr/lib/x86_64-linux-gnu/libboost_filesystem.a(operations.o): relocation R_X86_64_PC32 against symbol `_ZN5boost6system6detail10cat_holderIvE24system_category_instanceE' can not be used when making a shared object; recompilé avec -fPIC
/usr/bin/ld : échec de l'édition de liens finale : bad value
collect2: error: ld returned 1 exit status
[14/744] Building CXX object sdk/plugins/processing/classification/CMakeFiles/openvibe-plugins-sdk-classification.dir/src/algorithms/CAlgorithmClassifierLDA.cpp.o
../sdk/plugins/processing/classification/src/algorithms/CAlgorithmClassifierLDA.cpp: In member function ‘virtual bool OpenViBE::Plugins::Classification::CAlgorithmClassifierLDA::train(const OpenViBE::Toolkit::IFeatureVectorSet&)’:
../sdk/plugins/processing/classification/src/algorithms/CAlgorithmClassifierLDA.cpp:224:30: warning: comparison of integer expressions of different signedness: ‘Eigen::Index’ {aka ‘long int’} and ‘const size_t’ {aka ‘const long unsigned int’} [-Wsign-compare]
  224 |   for (Eigen::Index i = 0; i < nCols; ++i) {
../sdk/plugins/processing/classification/src/algorithms/CAlgorithmClassifierLDA.cpp:225:35: warning: comparison of integer expressions of different signedness: ‘Eigen::Index’ {aka ‘long int’} and ‘const size_t’ {aka ‘const long unsigned int’} [-Wsign-compare]
  225 |    for (Eigen::Index j = i + 1; j < nCols; ++j) {
../sdk/plugins/processing/classification/src/algorithms/CAlgorithmClassifierLDA.cpp:237:29: warning: comparison of integer expressions of different signedness: ‘Eigen::Index’ {aka ‘long int’} and ‘const size_t’ {aka ‘const long unsigned int’} [-Wsign-compare]
  237 |  for (Eigen::Index i = 0; i < nCols; ++i) { if (eigenValues(i) >= tolerance) { eigenValues(i) = 1.0 / eigenValues(i); } }
ninja: build stopped: subcommand failed.
Error while building OpenViBE
Does anyone know how to fix it please ?
Thanks a lot for your kind help
Cheers and have happy hollydays
Thomas
Re: Ubuntu 20.04 build Error
Post by Thomas »
Hi Mike_qp,
Thanks for the log, that's very helpful.
From what I see, OpenViBE tries to compile using the boost library of your system rather that the one installed as dependency.
I think the meaning is that the dependency installation didn't work fully for some reason.
You can confirm that by checking the content of the dependencies folder, in you src tree. Do you see the boost folder in it ?
On your machine the installation should work just fine. Maybe something went wrong when you experienced issues with git.
Could you try to delete the folders dependencies, external_projects/build and external_projects/arch, and rerun the install-dependencies script ?
If you could log the output of the script in order to look into it if the build still fails after that, that would be great.
All the best,
Thomas
Post Reply
