OV version - 3.2.0 build error
Post Reply
openvibeexplorer
Post by openvibeexplorer »
Hello,
I am trying to build the new version of OV (3.2.0) released in end of Oct.
I am getting the following error:
error LNK2038: mismatch detected for 'RuntimeLibrary': value 'MD_DynamicRelease' doesn't match value 'MT_StaticRelease' in ovCChrono.cpp.obj
Could you please let me know if there is some solution for this error?
Please Note: I am using the "Stable Source Code" for 3.2.0.
Regards,
Swati.
Thomas
Re: OV version - 3.2.0 build error
Post by Thomas »
Hi Swati,
Thanks for giving a try to the new release and for your feedback.
Would you be able to run a clean build (remove the build folder) into a log file (" .\build.cmd > build.log") and share the generated build.log file ?
Are you using the source archive or a clone of the git repositories ?
Thanks,
Thomas
openvibeexplorer
Hello Thomas,
Thanks for your prompt reply. I think it was just a matter of cleaning up the "build" folder.
It looks like my build is successful now. I could not attach the log because the file size was big.
So, I am uploading it at below location.
https://drive.google.com/file/d/1w2YaFF ... sp=sharing
The log file does not contain a success message. Also, the command prompt exited as soon as the build was done.
So I could not see the "SUCCESS" message at the end.
FYI - I have done a build of "source archive"
Regards,
Swati.
Thomas
Post by Thomas »
Hi Swati,
Thanks for sharing the log.
I had a look at it and indeed the build succeeded.
I take note of adding a nice success message at the end of the build process. ;-)
Cheers,
Thomas
openvibeexplorer
Thank you for all the help.
Regards,
Swati.
Post Reply
