OpenViBE forum
The OpenViBE community
It is currently Thu Jun 20, 2019 1:18 pm
Post new topic Reply to topic  [ 2 posts ]
Author Message
PostPosted: Thu Apr 26, 2018 1:03 pm
Offline
Hi to all,
after being looking a while for a proper way to build OpenViBE on Fedora 27, I finally succeed.
So, first good information for community: OpenViBE builds fine on Fedora 27 and also seems to launch and work normally :)
Now, how to build:
- all is on dependencies
- Do not use the script doing that, it only works for Ubuntu
- The dependencies list (in the txt files) is of course not good for Fedora users
So, just try installing following dependencies yourself:
Code:
dnf install eigen3-devel-3.3.4-3.fc27.noarch
dnf install xerces-c-devel-3.1.4-4.fc27.x86_64
dnf install gtest-devel-1.7.0-11.fc27.x86_64
dnf install liblsl-devel-1.11.0-10.fc27.x86_64
dnf install compat-lua-5.1.5-9.fc27.x86_64
dnf install compat-lua-devel-5.1.5-9.fc27.x86_64
dnf install fftw-devel-3.3.5-8.fc27.x86_64
dnf install freealut-devel-1.1.0-24.fc27.x86_64
And launch the build script:
Code:
./build.sh
At the end, do not forget to run openViBE with the shell launchers (that will set properly the ENV).
For example:
Code:
./dist/extras-Release/openvibe-designer.sh
Hope it would help some of you ;)
Enjoy !
Top
 Profile
PostPosted: Mon May 21, 2018 5:58 pm
Offline
Thank you very much! I made the post sticky so it stands on the top while we don't have official instruction for Fedora.
Cheers,
Jussi
Top
 Profile
Who is online
Search for:
Jump to:
Americanized by Maƫl Soucaze.
