OpenViBE forum
The OpenViBE community
It is currently Wed Jul 18, 2018 8:34 am
Post new topic Reply to topic  [ 6 posts ]
Author Message
PostPosted: Thu Nov 09, 2017 9:07 am
Offline
Hello all,
I tried searching for this problem everywhere online, and all i could find was that i need to install the lptrhead library, which I superfluously did (it was already installed)
I am running on Ubuntu 16.04.1 without plymouth (videocard issues) and Gnome desktop I followed the instructions and installed dependencies first.. everything was ok but at the end of the build it failed. I tried removing the build and tried again after update and upgrade... same exact error. Am I missing something obvious or is something wrong with either my ubuntu or with the build?
CMakeError.log:
Determining if the pthread_create exist failed with the following output:
Change Dir: /home/coristus/Downloads/openvibe-2.0.0-src/build/sdk-Release/CMakeFiles/CMakeTmp
Run Build Command:"/usr/bin/ninja" "cmTC_dbe9b"
[1/2] Building C object CMakeFiles/cmTC_dbe9b.dir/CheckSymbolExists.c.o
[2/2] Linking C executable cmTC_dbe9b
FAILED: : && /usr/bin/cc CMakeFiles/cmTC_dbe9b.dir/CheckSymbolExists.c.o -o cmTC_dbe9b && :
CMakeFiles/cmTC_dbe9b.dir/CheckSymbolExists.c.o: In function `main':
CheckSymbolExists.c:(.text+0x16): undefined reference to `pthread_create'
collect2: error: ld returned 1 exit status
ninja: build stopped: subcommand failed.
File /home/coristus/Downloads/openvibe-2.0.0-src/build/sdk-Release/CMakeFiles/CMakeTmp/CheckSymbolExists.c:
#include <pthread.h>
int main(int argc, char** argv)
(void)argv;
#ifndef pthread_create
return ((int*)(&pthread_create))[argc];
#else
(void)argc;
return 0;
#endif
Determining if the function pthread_create exists in the pthreads failed with the following output:
Run Build Command:"/usr/bin/ninja" "cmTC_ecd45"
[1/2] Building C object CMakeFiles/cmTC_ecd45.dir/CheckFunctionExists.c.o
[2/2] Linking C executable cmTC_ecd45
FAILED: : && /usr/bin/cc -DCHECK_FUNCTION_EXISTS=pthread_create CMakeFiles/cmTC_ecd45.dir/CheckFunctionExists.c.o -o cmTC_ecd45 -lpthreads && :
/usr/bin/ld: cannot find -lpthreads
Cheers
Top
 Profile
PostPosted: Thu Nov 09, 2017 5:07 pm
Offline
Hi,
Did you follow the process described in http://openvibe.inria.fr/build-instructions/#Building+on+Linux ?
Can you give us the output of the build.sh command ? (remove dist and build folders, and relaunch it)
Cheers,
Top
 Profile
PostPosted: Thu Nov 09, 2017 5:21 pm
Offline
Hi tgaugry,
Thank you for your reply.
Yes, I follow the instructions to the letter.. And I also removed and repeated the install as you suggest, with the exact same result. Which output would you like? The posted text is the exact text from the CMakeError.log generated by build.sh. Do you want the full log as well? or just the console output?
Top
 Profile
PostPosted: Fri Nov 10, 2017 12:40 pm
Offline
Hi,
Without the console output, i can't do much.
Can you post it here (in a file) ?
Thanks
Top
 Profile
PostPosted: Fri Nov 10, 2017 1:01 pm
Offline
No problem, when i get home tonight I'll get on it
Thanks .
Ok just deleted the dist and build directories.. reran build to and this is the result:
I replaced the physical home path with ~, in the actual file it is the real path.
File attached :)
build.txt [11.41 KiB]
Downloaded 37 times
Top
 Profile
PostPosted: Tue Nov 14, 2017 2:56 pm
Offline
Hi,
that's strange, to say the least !
We have a CI machine running ubuntu 16.04 which has no problem building the software.
Do you have the same values for the 2 following commands ?
Code:
ci@ubuntu1604:~$ uname -a
Linux ubuntu1604 4.4.0-96-generic #119-Ubuntu SMP Tue Sep 12 14:59:54 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
ci@ubuntu1604:~$ apt list --installed | grep thread
libboost-thread-dev/xenial,now 1.58.0.1ubuntu1 amd64 [installed]
libboost-thread1.58-dev/xenial-updates,now 1.58.0+dfsg-5ubuntu3.1 amd64 [installed,automatic]
libboost-thread1.58.0/xenial-updates,now 1.58.0+dfsg-5ubuntu3.1 amd64 [installed,automatic]
libpthread-stubs0-dev/xenial,now 0.3-4 amd64 [installed,automatic]
Top
 Profile
Who is online
Users browsing this forum: No registered users and 3 guests
Search for:
Jump to:
Americanized by Maƫl Soucaze.
