PSD estimate through Welch's method
don_matti
Post by don_matti »
Just wondering if anyone would benefit from Power Spectral Density estimation in OpenViBE.
I have found yet option with Welch windowing in Connectivity Measure box, but it is not the same imho. So far, OpenViBE supports FFT - Power Spectral Analysis and it could be more extended by mentioned algorithm.
Here's some useful links about this method:
http://www.mathworks.com/help/signal/ref/pwelch.html,
https://en.wikipedia.org/wiki/Welch's_method.
Thanks in advance for response!
Matt
Jeff_B
Re: PSD estimate through Welch's method
Post by Jeff_B »
Hi Matt,
I had the same idea while using the itpp library for the SpecCSP algorithm :) the Welch estimator is already implemented (see ITPP_EXPORT vec itpp::spectrum() at http://itpp.sourceforge.net/4.3.1/group__sigproc.html), and some other PSD estimators could also be among the options of such a box:
- like autoregressive Yule-Walker estimation (thanks to itpp::yulewalk for exemple).
- like Burg estimator (see in OV: ovpCAlgorithmARBurgMethod)
Jeff
elcinobacone
Post by elcinobacone »
Hi, we have a small group of neuroscience researchers and We would to know how calculate DSP signal about beta e theta bands. We're making an algorithm on OpenVibe designer but We don't know how integrate the function " ITPP_EXPORT vec itpp::spectrum()" implementing Welch method . We are not a programmers ...Can you help us?
