Sonification box
Jeff_B
Sonification box
Post by Jeff_B »
Hi Openvibers,
Should not be too much complicated, but has any of you developped a sonification box ? (on windows)
Jeff
Re: Sonification box
Hi Jeff,
you could try to use the OSC box to drive various synthesizers. Of course you'd need to design a meaningful DSP on either OV or the synth side.
Jeff_B
Post by Jeff_B »
Thank you Jussi. It's really a low priority questionning, but It's not as easy as I thought since I would like to be able to listen to the outputs of several spatiospectral filters, transposed / remapped in frequency / filtered (to be audible/compatible with the responses of the varied sound channels, to precompensate inequal sound channel responses), before being sent via SoundShare to a DTS or a 5.1 sound system (a multichannel system able to produce a sound relief). I am rather on the implementation of these spatiospectral filters right now :)
