OpenViBE forum
The OpenViBE community
It is currently Sun Jul 15, 2018 6:46 pm
Post new topic Reply to topic  [ 2 posts ]
Author Message
PostPosted: Thu Mar 05, 2015 9:35 am
Offline
Hello everybody,
I have written a script in python but for some reason OpenViBE lags when I run the script and I get an output like
Code:
[WARNING] <Player::can not reach realtime> 1 second(s) late...
I thought the problem was an infinite loop or so in my code, so I added debug info but it turns out OV seems to stuck between two OVBox.process() calls.
Here are the relevant parts (I hope!) of my code
Code:
   def process(self):
      print "new process"
      while len(self.input[0]):
         print 'start loop'
         buff = self.input[0].pop()
         if(type(buff) == OVSignalHeader):
            self.signalHeader = buff
            self.init()
            print 'init'
         elif(type(buff) == OVSignalBuffer):
            numpyBuffer = np.array(buff).reshape(tuple(self.signalHeader.dimensionSizes))
            signal.extend(numpyBuffer.T)
            prediction = best_cca() # returns either of [7,9,11,13,15,-1]
            self.send_stimulation(prediction, buff)
            print "sent stimulation", prediction
         elif(type(buff) == OVSignalEnd):
            outputEnd = OVStimulationEnd(buff.startTime, buff.endTime)
            self.output[0].append(outputEnd)
            print 'end'
      print 'end process'
   def init(self):
      outputHeader = OVStimulationHeader(
      self.signalHeader.startTime,
      self.signalHeader.endTime)
      self.output[0].append(outputHeader)
   def send_stimulation(self, prediction, buff):
      if prediction > 0: stim = OpenViBE_stimulation['OVTK_StimulationId_LabelStart'] + prediction
      else: stim = OpenViBE_stimulation['OVTK_StimulationId_NonTarget']
      stimSet = OVStimulationSet(buff.startTime, buff.endTime)
      stimSet.append(OVStimulation(stim, buff.endTime, 0.))
      self.output[0].append(stimSet)
with an output like
Code:
new process
end process
new process
start loop
sent stimulation 7
end process
This doesn't happen systematicly, but every five predictions or so... Does anybody know what mistake I have made?
Top
 Profile
PostPosted: Mon Mar 09, 2015 8:29 am
Offline
Hi Oettam,
one suspicious thing I see is that you're calling init from process(). This likely shouldn't be done.
To debug this, what I'd do is that I'd take the hello world example script
Code:
class MyOVBox(OVBox):
        def __init__(self):
                OVBox.__init__(self)
        def initialize(self):
                # nop
                return
        def process(self):
                # print something
                print("hello")
        def uninitialize(self):
                # nop
                return
box = MyOVBox()
and check that it runs properly. Then, line by line, start modifying it towards your script and see where the problem appears for the first time.
Happy hacking,
Jussi
Top
 Profile
Who is online
Search for:
Jump to:
cron
Americanized by Maƫl Soucaze.
