OV stops responding in python script
Re: OV stops responding in python script
Hi Oettam,
one suspicious thing I see is that you're calling init from process(). This likely shouldn't be done.
To debug this, what I'd do is that I'd take the hello world example script
class MyOVBox(OVBox):
        def __init__(self):
                OVBox.__init__(self)
        def initialize(self):
                # nop
                return
        def process(self):
                # print something
                print("hello")
        def uninitialize(self):
                # nop
                return
box = MyOVBox()
and check that it runs properly. Then, line by line, start modifying it towards your script and see where the problem appears for the first time.
