I'm a newbie to OpenVibe I'm not sure this is the correct section to put this question. I'm developing a plugin to find the significant wave type within EEG signal chunk. First i'm using a band pass filter then calculating power and calculating percentage of each type. So now I need to output what is my result or in other words name of the signal type and the value.
My question is how can I send use matrix display to show my output?
Is there any thing else i can do? My requirement is calculate the percentage and give feedback what has best percentage.
Thank you,
Nethanjan
