Hi everybody!
These days I've been trying to understand the ssvep-demo(directory:applications\demos\ssvep),
I've tried those five scenarios following the scenarios documentation(SSVEP). And I've basically known how Lua scripts and those boxes work.
But when I start to look at the source files(directory:applications\demos\ssvep\src) I found it hard to understand them because there are so many files and I don't know how they connect to each other.
So I've got some questions:
1.How to compile these sources?(for example I want to get the TrainerApplication compiled)
2.How to use Ogre to write the visualization parts of the trainer and shooter?(If I want to write a very simple visualization, do I have to learn Ogre separately? )
3.Which files should I look in to understand the VRPN parts of the demo?
Could anybody help me or can I find the answers somewhere in a doc which describes how this ssvep-demo was written ?
Best Regards,
Usain
Problems with the SSVEP-demo,about Ogre and VRPN
Re: Problems with the SSVEP-demo,about Ogre and VRPN
i have same problem, but in my case only need replic the experiment but i have problem to configure the box of different frequencies. i want four box because i need add one more frequencies because i want move a robot in four direction.
i have the answer.
you check this link, https://github.com/alexandrebarachant/o ... -demo.conf
and you need modiffy all file of that directory.
