It is currently Tue Feb 20, 2018 11:19 pm
PostPosted: Tue Jul 05, 2011 6:44 am
Sir,
I am trying to read the EEG signals using openViBE acquisition server but in my pc serial port IO address range is below 1024 (below 3FF) so i could not able to read.
In the openViBE acquisition server i could not able to set the port address below 1024.So please help me to solve this problem.
Similarly i am interested to know if my EEG machine is having usb connectivity then how to read EEG signals using openvibe acquisition server.
Thanks and regards
Rajesh M.
PostPosted: Tue Jul 05, 2011 9:13 am
Hi Rajesh,
Can you remind us the EEG device you are using please ?
The hostname/connection port values in the Acquisition server are used for the TCP/IP network connection between the Acquisition server and the Designer.
User-defined connection ports start at 1024, lower are reserved for defined protocols. It is not a serial port number.
USB, Bluetooth, Serial port... in fact the connection type is not a problem. What's important is how you can communicate with your device, start the acquisition, retrieve samples, etc.
Your device should come with something... for example a SDK (the simplest case) or just the communication protocol (very low-level case).
Anyway, if your device is not yet compatible with OpenViBE, you would have to implement a new driver for the acquisition server.
Hope this helps
_________________
PostPosted: Fri Dec 14, 2012 9:47 am
Hope this helps
Link is broken,
I think the right one is
http://openvibe.inria.fr/tutorial-creat ... on-server/
