Error when starting tie-fighter
Nathali
Post by Nathali »
when trying to start demo-tie-fighter.cmd got runtime error, w/o any further details. My question is if there are any constraints what OS to use, etc. (currently was tried on win xp sp3, and vista. openvibe was downloaded today from the site)
Thank you for your time and consideration.
Nathali
jlegeny
Re: Error when starting tie-fighter
Post by jlegeny »
Dear Nathali,
currently tie Tie Fighter demo is know to not work in virtual machines. In the case you are not using a virtual machine - there was recently a similar problem handled on the forums and was solved by installing current graphics drivers.
In case this does not help you, I'd like you to provide a copy of the log created by OpenViBE prior to the error.
