VR application: get more precise calls to process function ?
ntarrin
Post by ntarrin »
I'm trying to precisely control flashings in an openvibe P300 VR application.
In "COgreVRApplication::frameStarted", I removed tests on frequency and sleeps, so that "this->process" is called each time "frameStarted" is.
In my process function, I measured elapsed time using Ogre timers.
std::vector<double> m_vRepetitionPerformance;
Timer perfTimer;
m_vRepetitionPerformance.push_back(perfTimer.getMicroseconds());
perfTimer.reset();
All this is compiled in release mode, run on Imac/Intel Duo 2,6G/windows XP/NVIDIA GeForce 9400 - 60Hz. An openvibe designer is running a P300 replay scenario in the background.
The measured refresh rate looks like this :
refresh rate 3.jpg (6.38 KiB) Viewed 4840 times
x: elapsed time since last call in µs.
y: number of frame for each time window
I expect to have at most 16ms (1/60) between each frame, and we see several calls at 20ms and more. Is there a way to avoid this in Ogre ? Or am I missing something ?
Thanks.
Nicolas.
lbonnet
Re: VR application: get more precise calls to process functi
Post by lbonnet »
Hi Nicolas,
Sorry but I don't know how you can optimize the Ogre process...
Do you know the precision of the Ogre Timer ?
we know there is some problem when measuring time using the Windows Time::getTime function (minimum 15ms refresh), bu I don't know the Ogre timer...
ntarrin
Post by ntarrin »
I've done a little test with ogre timer:
for (int i=0; i<1000; i++)
	perfTimer.reset();
	Sleep(5);
Which gives:
ogre timer precision.jpg (12.24 KiB) Viewed 4831 times
This should be ideally centered on 5000. It looks like this timer is at least 1ms precise, which is ok for my needs. Is there an openvibe timer ?
Below is the flash durations I have, expecting 100ms each:
flash rate 7.jpg (13.77 KiB) Viewed 4831 times
Most of them are between 100 and 110ms, which is acceptable, but it can be up to 130 or 140ms. I guess I'll have to deal with this performances...
Did you measure your flash durations for the P300 speller scenario ?
Dear Nicolas,
no we did not measure the flash duration of the P300 scenarios
Did you solve the timing problems you were facing ?
ntarrin
Post by ntarrin »
Hi Yann,
Nope, for the moment I'll use this as is, flash precision is not that bad, and if we need more precise durations, it may heavily depend on Ogre engine. After a quick search on the net, I found nothing about having Ogre calling the frameStarted callback more steadily. If someone find something, I'll be happy to take benefit from it :)
Nicolas.
