How do communicate OpenViBE with other App
gibfen
Post by gibfen »
Hello everyone!
I was wondering how can I use a generated data ('Signal Stream') in OpenViBE to "control" other application (eg: bloc note on Windows).
Let's say that the 'Signal Stream' generated in OpenViBE has a sample frequency of 128 Hz, but it only has several fixed values: -1, 0, 1.
So, the idea is when I have a '-1' in that 'Signal Stream' i want to write in bloc note a string like "bad". If I have a '1' i will write "good". If I have a '0' I won't write anything.
The purpose is not using the bloc note, but I think it is a convenient start to understand how to deal with these communication. Next step would be, using that data in a videogame that Emotiv provides for testing. Really, no clue how to do this...
I will appreciate your help :)
Best!
jlegeny
Re: How do communicate OpenViBE with other App
Post by jlegeny »
Hello gibfen,
OpenViBE can indeed communicate with external applications, as long as they support VRPN connection. You can look at this tutorial: http://openvibe.inria.fr/vrpn-tutorial- ... plication/
other methods can be implemented as well by using the script boxes, such as the Lua box (for example you could use Lua sockets to communicate with your application).
