I am migrating (trying to) old driver interfaces (glade to ui) but it is far not so easy as presented in your post-it.
For example, I open my old interface with glade 3.6 ; I can see what it look like. I save it as ui (with gtkbuilder) [you can see already in the last post, it is not so easy with combobox...]. Here, it seems ok.
Then I transform with your help, which seems to be enough.
But unfortunately the visual interface is not the same : all elements (or near) disappear an the style is poor.
This migration is necessary but it take many many time for something ridiculous! How could you help us the best?!
about libglade migration
Re: about libglade migration
Dear Matthieu,
thank you for your message.
The best I can do at this point is ask you to send me your source code, your .glade file and I'll do it for you.
