documentation openvibe
matthieuG
Post by matthieuG »
The documentation explain how to build doc.dox-part and doc.dox-skeleton, but next steps are not clearly described. What and how to use Cmake to produce doxygen documentation?
lbonnet
Re: documentation openvibe
Post by lbonnet »
Hello MatthieuG,
The documentation is generated along with the applications when you run the build script. Everything ends in
/openvibe-documentation/. If you are running on Windows, we currently have some problems: CMake does not parse every subdirectory, thus the documentation is not generated correctly. But if you build on linux, you should have your documentation (html / latex) in the /openvibe-documentation/ directory.
I hope this helps !
matthieuG
Post by matthieuG »
so the good way is usually :
_create a dox-part in plugins\src\doc
_create a dox-skeleton in openvibe-documentation
-lunch the build script (win32- or linux-build)
But under windows, it doesn't process, does it!
The result of process should appear in openvibe-documentation?
lbonnet
Post by lbonnet »
You don't even have to do it yourself ;)
run the openvibe-plugin-inspector, it will check all existing boxes, and create the xxxx.dox-part-skeleton and xxxx.dox-skeleton files for you. The 2 files will be in /openvibe-documentation. Copy-paste the xxxx.dox-part-skeleton file in openvibe-plugins/[path-to-your-plugin-branch]/src/doc, rename it to xxxx.dox-part and complete it.
then run the linux build script, and watch the result in /openvibe-documentation.
Indeed, it doesn't process under Windows.
Your question have made us think about our current documentation tutorial, which is incomplete. We will certainly update it to be more precise, and include the plugin-inspector usage.
- EDITED (Tue Dec 8) -
matthieuG
Post by matthieuG »
It would be a very good idea to generate documentation pattern with plugin-inspector. At present, it seems it doesn't.
lbonnet
Post by lbonnet »
I edited my last reply to be more precise.
The plugin-inspector generates such pattern, it's the xxxx.dox-part-skeleton file. This file contains every tags such as :
 * |OVP_DocBegin_BoxAlgorithm_XXXX_Input1|
 * |OVP_DocEnd_BoxAlgorithm_XXXX_Input1|
You just have to fill the file between these tags with your documentation, copy the file in your plugin folder and rename it xxxx.dox-part.
Hope this helps
