Hi,
We're a group of students that are doing a project with BCI and OpenVibe. Currently we've been getting some good results from the Motor Imagery application in OpenVibe, but now we want to "extract" the results to some sort of I/O. Unfortunately, this is all new to us and we are not sure how to approach this. For example, we would like to control an arduino lamp by "thinking" left/right, instead of controling the csp trial program.
What's the easiest way to do this? Use the Scenario I/O or python scripting? And how should we do?
Extracting the output from Motor Imagery
Re: Extracting the output from Motor Imagery
Hi,
I'm not an expert of network process. But The easiest for you I think is python because python is easy.^^ BUt i term of speed and regularity I don't know. Actually I use LSL to communicte with external software. You have a box LSL Export.
Thibaut
Thibaut
