Hey,
So I am trying to develop a box that visualized a streamed matrix by using MATLAB scripting box. What I would like to do is to add settings on the box, which I will use for the functions in MATLAB. I succeed in creating the functions I need however I tried to add a specific setting and modify the type of the setting which did not succeed. For instance, I would like a value that can be either 'true' or false, the type will be a boolean. However, each time I try to override the setting, the type of the setting stays 'undefined'. So, I was wondering if someone encountered this problem and could be able to help me further.
Kind regards,
Eduardo A. Bracho Montes de Oca
OpenVibe Designer and Changing Box Settings
