How to make the motor imagery CSP work ?
Posted: Thu Jul 26, 2018 9:39 am
It has been a while since I have tried to make the motor imagery csp scenario work.
At first I was using the emotive headset which didn't have the required electrodes (like cz ,c1,c2,c3).
so I switched to Mitsar 202 which did cover that area and had 31 channels.
I also read in the forum that exercising is required for motor imagery. there were two articles mentioned :
"Graz-BCI: State of the Art and Clinical Applications", G. Pfurtscheller, C. Neuper, G. R. Müller, B. Obermaier, G. Krausz,
A. Schlögl, R. Scherer, B. Graimann, C. Keinrath, D. Skliris,, M. Wörtz, G. Supp, and C. Schrank,
IEEE Trans. Neural Systems and Rehabilitation Engineering, 2003.
"Control of a two-dimensional movement signal by a noninvasive brain–computer interface in humans",
Jonathan R. Wolpaw and Dennis J. McFarland, PNAS, 2004.
but neither had any info about any type of exercise that would improve motor imagery so I just practiced by actually doing the hand movements (opening and closing my right/left hand) and also practiced some imagery.
I also tried adjusting two other parameters :
1. Temporal filter interval : I ran scenarios 2 and 3 for intervals of 8-12,12-16, ...,28-32 (Hz) in the temporal filter. the reported accuracy of cross validation in the best interval(20-24) was 80 percent which was almost the same as using the general filter of 8-30. But when I used scenario 4 and 5 to get new data and to test for the real accuracy of the model I got an accuracy of 60 at best. and for other cases I got an accuracy of 50% (technically non). (I also adjusted the filter interval in scenario 4 and 5)
2. Length of training: I also tried making each instance of right/left imagination longer in scenario 1 by 4 sec. I thought that having more data would help. I also made the offset 1 sec instead of 0.5 but it decreased the accuracy of cross validation and for new data I got an accuracy of 50% again. (I also adjusted all the "stimulation based epoching" boxes)
to check for the accuracy of the model I ran scenario 4 once. then adjusted scenarios 2,3,5 for different cases and used the file recorded in scenario 4 in scenario 5.
I thought about changing the classifier (I used the default LDA). But it seems that wouldn't help since I have no accuracy at all.
here are my final thoughts:
1.in case the data I record from myself is not good. Is there a way to test the scenario on prerecorded data? are there any proper recordings of motor imagery available online? is there an easy way of running the scenario on them ?
2. even considering that the scenario works well on the prerecorded data how can I make the scenario usable for untrained people that are going to use it ?
Best regards,
Kiyarash
Best regards,
Kiyarash
