Defining a trained classifier as a global variable in Matlab
eli.young
Post by eli.young »
Hello! I have an already trained classifier and a I need to load it only once, when pressing play to the scenario. I'm using a Matlab Scripting Box, and I want to know if it should be loaded in the "Initialize" script of the box and declared as global (an how to use it after that) or if I should do it in the "Process" script.
Thank you! :D
Re: Defining a trained classifier as a global variable in Ma
Hello Eli,
global variables can get a bit messy, so I recommend doing it like this,
       % in initialize.m
       box_in.user_data.classifier = myClassifier; % store your loaded classifier
       box_out = box_in;  % pass it out to openvibe
       % in process.m
       myClassifier = box_in.user_data.classifier;  % take the classifier from openvibe
       % use it somehow
For reference, the global variable solution would look like
     % in initialize.m
     global myClassifier;
     % do something to initialize it, load from disk or whatever
     % in process.m
     % use it somehow
In any case, if you have a premade classifier, you should definitely load/build it in initialize unless you have some reason to do it in process.
eli.young
Post by eli.young »
jtlindgren wrote:Hello Eli,
       % in initialize.m
       % in process.m
       % use it somehow
     % in initialize.m
     % in process.m
     % use it somehow
Thank you! It helps a lot!! :D :D
