mi-csp csp filter error
Posted: Sun May 21, 2017 7:03 am
I was running the mi_csp scenario when i got the error
".... CSP Spatial Filter> Bad matrix size _ Filter has 11 channels but data needs 16 channels"
I 'am using emotiv epoch+ and I think I know where the problem arises.
in the scenario mi-csp-1-acquisition . using signal display I figured out the "Acquisition client" box gives all the 16 channels to the "generic stream reader" box but only 11 is read in mi-csp-2 .
can sb help ?
edit
ok i think the problem is that in the defaul example in "mi-csp-1-acquisition" the address for the writer is :
${Player_ScenarioDirectory}/signals/motor-imagery-csp-1-acquisition-[$core{date}-$core{time}].ov
BUT in the "mi-csp-2" the address for the reader is :
"${Path_Samples}/signals/bci-motor-imagery.ov"
so I changed both of them to :
but then scenario 2 wouldn't end even after fast forwarding . so I thought that it might be becuse all the last recordings were concatenated to the same file (I tried it with the other address same result!) so I decided to make a new .ov file of my own but how can I do that?
can sb help ?
edit
