It is currently Wed Oct 23, 2019 10:20 am
PostPosted: Tue Sep 06, 2016 8:21 am
Hello, what I am trying is to change generic accuisition server to Biosemi ActiveTwo server and keep the rest of tutorial neurofeedback paradigms - voxel visualization. I don't know why it doesnt work since I can plot signal in real time and see channel labels. I simply switch these and it doesn't work. Even in other paradigm for 2D a 3D topography.
Can you please tell what I am doing wrong? Is it sometnig like channel localization? I haven't found any useful infomration on web.
Michael
PostPosted: Wed Sep 07, 2016 7:38 am
Hi, does it print any warnings or errors? Generally you need to have the channel localization information exactly matching the channels you get from your device. The channel localization file is just a text file, you can make a copy of the file used in the tutorial scenarios' channel localization reader box and modify it: in the file, you specify name of each channel and its x,y,z coordinates. Next, make the channel localization reader box use your new file.
PostPosted: Thu Sep 08, 2016 8:48 am
Hi, thank you for you kind help!
It doen't give any errors. I am pretty desperate with it (I try to get this thing working for months now).
I have Biosemi ActiveTwo 64 channel EEG (for OpenVibe I use only 32 channels) with Fs = 2048 Hz, without any EOG and ECG channels. I have official channel localization file from Biosemi (see attachement) so I changed values of OpenVibes cartezian file to this one to fit.
Then I build regular paradigm for raw and filtered signal inspection in OpenVibe and everything is fine (channels have names and signal is more or less ok). But using 2D topogrpahy still doesn't work at all. I put my modified file in channel localization box. See my files in attachement. I guess it could be some problem with CMS and DRL channels which are reference in Biosemi.
Biosemi official coordinates of channels: http://www.biosemi.com/download/Cap_coords_all.xls
File comment: Biosemi localization files (modified OpenVibes original file)
biosemi_channel_localization.txt [5.53 KiB]
Downloaded 169 times
File comment: This is my 2d topography file
biosemi_2d_topography.xml [21.57 KiB]
Downloaded 187 times
