I'm trying to change the matrix size of the P300 magic card from 3x4 to 3x5 successfully, my issue here is that the last image in the last row is not showing (Please refer to the attachments).
How can I fix that?
Missing an image in P300 magic card
- Untitled2.png (107.21 KiB) Viewed 3671 times
- Untitled.png (152.17 KiB) Viewed 3671 times
Re: Missing an image in P300 magic card
Does anyone have an idea about this?
I found this: viewtopic.php?f=17&t=573&p=2802&hilit=m ... mber#p2802
Unfortunately, it didn't work for me.
The problem shows when I add new column. It deletes tow images from the last row and when I intend to add pictures in the fifth column the designer crashes even though I've edited the header and recompiled the project.
What to do?
What to do?
