How to connect p300 speller to an online client
Posted: Thu May 19, 2016 7:04 pm
"the default online scenario uses a Generic stream reader to read data from a recorded session. Connect the Acquisition client instead if you want online acquisition."
I tried to create a Acquisition client box but there was only one output port for simulations and the identity box needs two. I tried to add an output stream to the Acquisition client box and no luck.
I also tried to work with only one, it didn't work as expected and there were no flashing what so ever.
What should I do to make it work?
