"the default online scenario uses a Generic stream reader to read data from a recorded session. Connect the Acquisition client instead if you want online acquisition."
I tried to create a Acquisition client box but there was only one output port for simulations and the identity box needs two. I tried to add an output stream to the Acquisition client box and no luck.
I also tried to work with only one, it didn't work as expected and there were no flashing what so ever.
What should I do to make it work?
How to connect p300 speller to an online client
Re: How to connect p300 speller to an online client
Hi, which openvibe version are you using? In 1.2.0, the use of streams in the P300 scenarios have changed, and the default input of the online scenario is no longer the generic stream reader.
Yes, thank you.
