Computer spec for 2 player P300 based BCI
Posted: Wed Feb 04, 2015 12:59 pm
Dear Openvibe team
I want to try P300 BCI with 2 players where both compete with each other to select the alphabet. We use Emotiv as our EEGs. Our computer spec is i5 2.0GHz with 4GB of Ram using Windows7 32 bit. We use Openvibe version 0.17. We use 2 acquisition servers to connect to both EEGs. First we tried to make sure that Openvibe can read data from both EEGs simultaneously and from the graph everything looks Ok. Then, in the file p300-speller-1-acquisition, we use 2 acquisition servers to connect to 2 EEGs and ask both test subjects to focus on the matrix speller. Once done, we train the filter and classifier using the file p300-speller-2-train-xDAWN and p300-speller-3-train-classifier, respectively. Each test subject got around 80% of accuracy. Then, we try p300-speller-4-online where both test subjects simultaneously focus on the matrix speller and try to select the alphabet independently. However, none of them get accurate results from p300-speller-4-online. We tried the same scenario using i7 3.0GHz with 8GB of RAM using Windows7 64 bit. During training, both test subjects got around 95% and 86% of accuracy. Then, when we tried p300-speller-4-online, one test subject got 3 accurate alphabet selection out of 10 while the others got none.
From the scenario, we suspect that computer specification might limit the ability of Openvibe to run P300 Matrix speller with 2 users. Any recommendation about the computer spec for running P300 Matrix speller with 2 users simultaneously? Also, we suspect that the delay due to running 2 users simultaneously might impact the flash timing and hence selection accuracy. Any recommendations for checking delay or jitter when running P300 BCI?
Thank you very much for your kind help
-Jim
-Jim
