having trouble executing ssvep-bci-1-ssvep-configuration.xml
rainydhiya
Post by rainydhiya »
hi all,
i'm having trouble executing this bci examples provided by Openvibe
as i'm also not familiar with lua script (i've googled it but still cannot understand)... i cannot understand this error and why is it happening...
so somebody help me!! :( :( :(
the error are:
At time 0.000 sec <Box algorithm::(0x00001058, 0x00002825) aka Peripheral Settings> Lua script terminated
Re: having trouble executing ssvep-bci-1-ssvep-configuration
Hi, if you are on Windows, copy the scenario folder somewhere where you have write access (that is, NOT under program files...), and reload it from there.
Generally 'lua script terminated' is not an error, it just means the script did its thing and exited.
