Add library files
chantrip
Add library files
Post by chantrip »
Hi
From this post viewtopic.php?f=17&t=9316, we tried a couple of files but it still didn't work. Could you please be more specific by giving some example? E.g. if I want to add graphic.h in the file ovpCBoxAlgorithmP300SpellerVisualisation.cpp, which files or paths that I should edit?
Thank you very much
-Jim
