hello everyone,
when i run the program 5-online-test-shooter from the source code
the error comes out as:
[F:/openvibe-0.17.1-src/applications/demos/ssvep-mind-shooter/bci-examples/ssvep-mind-shooter/configuration/temporal-filter-freq-2h1.cfg] could not be opened
[ ERROR ] Scenario (0x00007489, 0x0000452d) setting modification with acceptVisitor() failed
but the .cfg file is turely there,how should i do to fix it?
thank you !
*.cfg could not be opened
Re: *.cfg could not be opened
The path may be too long.
Also, the scenario should be opened under the dist/ folder where everything is installed. It only looks for config under the source tree if you open the scenario there.
SSVEP tutorials,
http://openvibe.inria.fr/steady-state-v ... otentials/
http://openvibe.inria.fr/using-the-ssve ... scenarios/
SSVEP tutorials,
