It is currently Sat May 25, 2013 9:13 am
PostPosted: Tue Feb 21, 2012 10:35 pm
I want to control a robot arm that uses parallax servo controller. It uses pbasic to control the servos. I need to take the live stream data from Open Vibe and open it in the pbasic file and decide on how to move the servos. What are my choices to doing this easily. Is there a file or a port that I can connect to and get the data.
Thank you.
PostPosted: Wed Feb 22, 2012 1:04 pm
Hi s.ri08 and welcome on board,
As usual, we recommend using VRPN protocol to communicate with OpenViBE, via VRPN analog and button boxes.
You will find many posts on this forum related to the use of VRPN protocol.
This tutorial gives an example of C++ 3D application that uses VRPN to get data from openvibe.
The following tutorials are much more recent :
From an external application to OpenViBE
From OpenViBE to an external application
Hope this helps !
_________________
Users browsing this forum: Google [Bot] and 1 guest
cron
POWERED_BY
Translated by MaĆ«l Soucaze © 2009 phpBB.fr
