I am working on a project for school and I first got the normal headset they first bought. Now I got the research SDK but still have the normal headset with it. Will I be able to work with that one too or do I need the dev headset?
I am trying to get the P300-speller to work with it so I am eliminating possible errors.
tnx in advance
Emotiv Research with normal headset
Re: Emotiv Research with normal headset
Hi
Dieter
I thought the headsets are the same, but I guess that is a question that you will have to direct to Emotiv.superdelux wrote:Hi,
A helpful hint could be to use a lot more averages in the OpenViBE P300 scenario to deal with the lower signal-to-noise ratio of the headset. Start with 20 or 30.superdelux wrote:I am trying to get the P300-speller to work with it so I am eliminating possible errors.
tnx in advance
Dieter
