IIR Filter
Working with OpenViBE signal processing scenarios and doing scenario/BCI design
Post Reply
fah
IIR Filter
Post by fah »
Hi,
I try to run the method "void IIR_Filter (b vec, vec a, vec data, vector V0, dataFiltered & vec, vec & Vf) " in ovpCApplyTemporalFilter. Can you describe me exactly what each parameter correspond? I think that b and a are the numerator and denominator of the transfer function of the filter.
thank you for your help!
yrenard
Site Admin
Contact:
Re: IIR Filter
Post by yrenard »
Dear fah,
the original authors Emmanuel Maby and Guillaume Gibert don't visit this forum much. I suggest you contact them directly if you want details on their implementation of this temporal filter.
Hope this helps,
Yann
Post Reply
