I try to run the method "void IIR_Filter (b vec, vec a, vec data, vector V0, dataFiltered & vec, vec & Vf) " in ovpCApplyTemporalFilter. Can you describe me exactly what each parameter correspond? I think that b and a are the numerator and denominator of the transfer function of the filter.
thank you for your help!
IIR Filter
Re: IIR Filter
Dear fah,
the original authors Emmanuel Maby and Guillaume Gibert don't visit this forum much. I suggest you contact them directly if you want details on their implementation of this temporal filter.
