Hi!
I don´t know why but, when the Train Classifier ends, doesn´t generates the .cfg data
Can anyone help me please?
I have this scenario
Problem generating .cfg in Speller train classifier
- Dibujo.JPG (23.07 KiB) Viewed 5467 times
Re: Problem generating .cfg in Speller train classifier
I am expecting something like this in the classifier part but it doesn´t happen
[ INF ] At time 1195879956480 (0x11670000000)<Box algorithm::Classifier trainer> k-fold test could take quite a long time, be patient
[ INF ] At time 1195879956480 (0x11670000000)<Box algorithm::Classifier trainer> Finished with partition 1 (0x1) / 20 (0x14) (performance : 87.3239%)
[ INF ] At time 1195879956480 (0x11670000000)<Box algorithm::Classifier trainer> Finished with partition 2 (0x2) / 20 (0x14) (performance : 91.6667%)
[ INF ] At time 1195879956480 (0x11670000000)<Box algorithm::Classifier trainer> Finished with partition 3 (0x3) / 20 (0x14) (performance : 83.3333%)
[ INF ] At time 1195879956480 (0x11670000000)<Box algorithm::Classifier trainer> Finished with partition 4 (0x4) / 20 (0x14) (performance : 81.6901%)
[ INF ] At time 1195879956480 (0x11670000000)<Box algorithm::Classifier trainer> Finished with partition 5 (0x5) / 20 (0x14) (performance : 87.5%)
[ INF ] At time 1195879956480 (0x11670000000)<Box algorithm::Classifier trainer> Finished with partition 6 (0x6) / 20 (0x14) (performance : 80.5556%)
[ INF ] At time 1195879956480 (0x11670000000)<Box algorithm::Classifier trainer> Finished with partition 7 (0x7) / 20 (0x14) (performance : 85.9155%)
[ INF ] At time 1195879956480 (0x11670000000)<Box algorithm::Classifier trainer> Finished with partition 8 (0x8) / 20 (0x14) (performance : 83.3333%)
[ INF ] At time 1195879956480 (0x11670000000)<Box algorithm::Classifier trainer> Finished with partition 9 (0x9) / 20 (0x14) (performance : 80.5556%)
[ INF ] At time 1195879956480 (0x11670000000)<Box algorithm::Classifier trainer> Finished with partition 10 (0xa) / 20 (0x14) (performance : 86.1111%)
[ INF ] At time 1195879956480 (0x11670000000)<Box algorithm::Classifier trainer> Finished with partition 11 (0xb) / 20 (0x14) (performance : 80.2817%)
[ INF ] At time 1195879956480 (0x11670000000)<Box algorithm::Classifier trainer> Finished with partition 12 (0xc) / 20 (0x14) (performance : 77.7778%)
[ INF ] At time 1195879956480 (0x11670000000)<Box algorithm::Classifier trainer> Finished with partition 13 (0xd) / 20 (0x14) (performance : 81.9444%)
[ INF ] At time 1195879956480 (0x11670000000)<Box algorithm::Classifier trainer> Finished with partition 14 (0xe) / 20 (0x14) (performance : 78.8732%)
[ INF ] At time 1195879956480 (0x11670000000)<Box algorithm::Classifier trainer> Finished with partition 15 (0xf) / 20 (0x14) (performance : 79.1667%)
[ INF ] At time 1195879956480 (0x11670000000)<Box algorithm::Classifier trainer> Finished with partition 16 (0x10) / 20 (0x14) (performance : 83.3333%)
[ INF ] At time 1195879956480 (0x11670000000)<Box algorithm::Classifier trainer> Finished with partition 17 (0x11) / 20 (0x14) (performance : 80.2817%)
[ INF ] At time 1195879956480 (0x11670000000)<Box algorithm::Classifier trainer> Finished with partition 18 (0x12) / 20 (0x14) (performance : 80.5556%)
[ INF ] At time 1195879956480 (0x11670000000)<Box algorithm::Classifier trainer> Finished with partition 19 (0x13) / 20 (0x14) (performance : 79.1667%)
[ INF ] At time 1195879956480 (0x11670000000)<Box algorithm::Classifier trainer> Finished with partition 20 (0x14) / 20 (0x14) (performance : 76.3889%)
[ INF ] At time 1195879956480 (0x11670000000)<Box algorithm::Classifier trainer> Classifier performance on whole set is 82.2878%
Hi Tonio,
I think that the trainer is not getting the Trigger for stimulation. Try using the keyboard stimulator, and don't forget to change the Train Trigger Stimulation to that of the Keyboard. I hope that it will work.
Thanks.
Thanks.
uahmed you were right, thank you very much.
The Lua script had a problem and did not sent the train trigger.
I fixed and now works fine,
thanks
thanks
