Hey,
How can I modify the Graz visualisation to show only one arrow going up?
Karthik
Modifying the Graz visualisation
Karthik
Karthik
Re: Modifying the Graz visualisation
Dear karthiks,
you should look into openvibe-plugins/simple-visualisation/trunc/src/ovpCGrazVisualisation*. Hopefully, you will find what you need.
Ah thanks Yann. I shall do that.yrenard wrote:Dear karthiks,
I was hoping maybe it would be something in the XML since it controls the scenario.
Karthik
Karthik
Indeed, sending stimulation OVTK_GDF_Up should show the up arrow. OVTK_GDF_Down shows the down arrow as well. I think there are issues with the feedback that won't allow it to be vertical with the current state of this box.
Does it fit your needs ?
Dear Yann,yrenard wrote:Indeed, sending stimulation OVTK_GDF_Up should show the up arrow. OVTK_GDF_Down shows the down arrow as well. I think there are issues with the feedback that won't allow it to be vertical with the current state of this box.
Yea my issue was with the feedback part too. Guess will have to dwell a bit deeper and dust off the C++ stuff
Thanks again for the help
Karthik
Karthik
