MI classified output with Hyperplane distance
harithhansaka
Post by harithhansaka »
I'm using the MI-CSP replay scenario. To get classified output to python, I've used chunk hyperplane values. But problem is, in both directions, those values are positive. To identify the direction, one direction should get positive and the other should get negative?
https://ibb.co/42WSC08
https://ibb.co/VJ0YhKm
https://drive.google.com/file/d/1R9HExD ... sp=sharing
https://drive.google.com/file/d/159lSVe ... sp=sharing
Thank you,
BR,
Harith
Re: MI classified output with Hyperplane distance
Post by Thomas »
Hi Harith,
To identify the direction using the values provided in by the hyperplane output of the processor, you can do the following:
if (len(chunk) == 2):
	v1 = int(chunk[0])
	v2 = int(chunk[1])
	sum = v1 +v2
	// if sum = 0, neither left or right
	if (sum == 0):
		res = 0
	else:
		res = v2/sum - v1/sum
	if(res > 0):
		print("Right")
	if(res <):
		print("Left")
	else:
		return
I haven't tested it, but the logic is here.
harithhansaka
Thank you Thomas.
