Using and modifying P300: Magic Card
Working with OpenViBE signal processing scenarios and doing scenario/BCI design
Post Reply
Diane
Post by Diane »
Hello :D
I am a first year student in an engineering school. For one of my project, I need to learn how to use OpenVIBE. More precisely, I need to be able to put images in the matrix and change the characters in the matrix. I had a hard time learning how to do this. I tried using Glade to change the script but the system tells me that the version of glade is too recent to take in charge the P300 speller's script. I talked about my difficulties with some of the professors around me and they had no clear answer. One of them told me to use the P300: Magic card scenario, but I can't modify it or even test it.
Mastering OpenVIBE is not the purpose of my project. Can you give me the instructions (as detailed as possible) to change the characters and put images ? I will be eternally thankful ^^
Sincerely,
Diane
Post Reply
