why a 2 class classification is used in motor imagery
About BCI and box tutorial/demo scenarios bundled with OpenViBE.
Post Reply
kiyarash
Post by kiyarash »
in the motor imagery csp scenario provided we want to detect right or left hand imagiation using the algorithm. shouldn't it use a 3 class classification since there are 3 states : imagining right hand movement, imagining left hand movement and also imagining nothing.
wouldn't this make the scenario work inaccurately?
thanks
kiyarash
jtlindgren
Re: why a 2 class classification is used in motor imagery
Post by jtlindgren »
Hi,
some research papers use an additional 'nothing' class, some do not. The Graz paradigm in openvibe is defined as two class; since during training and testing it is *assumed* that the user is a good boy/girl/person and obediently imagines of only left or right (as instructed) during the trial, this limited context is not requiring a third class. From real use perspective (for example controlling something), a third class of nothing could be useful. Adding a third class will also change the classification problem in a machine learning sense. How it will change it is doubtlessly a research question in itself. If anybody knows related links, feel free to post. :)
Cheers,
Jussi
Post Reply
