hi all,
I want to use matalb script box, the input to it is from channel selector from real signal, how can I make a loop from the first value until the last value and compare with specific value?
I am junior using openvibe
thanks for your help
matlab script
Re: matlab script
Hi Sabeel Akhras,
I suggest you to have a look at this tutorial explaining how to use Matlab in OpenVibe:
I believe that after following this tutorial you'll be able to implement what you need.
Best regards
Best regards
