Bipolar Montage
Athan
Bipolar Montage
Post by Athan »
Hi all,
Do you know how can I setup an example with a bipolar montage using gtec gmobilabplus?
Will I have to use the reference box for subtracting the channels or the channel selector (e.g. FC3-CP3 for C3)?
Thanks.
fabien.lotte
Re: Bipolar Montage
Post by fabien.lotte »
For creating bipolar channels, the easiest way is probably to use the spatial filter box, which combines channels as a weighted linear combination that you specify.
So you can used it to subtract pairs of EEG channels.
I hope this helps,
Fabien
