Error on PATH when connecting Emotiv
sumitsoman
Post by sumitsoman »
I am getting the following error when using the OpenVibe Acquisition Server with the Emotiv Headset.
[  INF  ] Connecting to device [Emotiv EPOC]...
[ ERROR ] [INIT] Emotiv Driver: Failed to get the environment PATH.
[  INF  ] Disconnecting.
The Emotiv Control Panel and TestBench are working fine. I am using the Emotiv Research Edition SDK_v1.0.0.5-PREMIUM, on a 64-bit Windows 7 machine. I had set the path in the Driver Properties to the Emotiv Research Edition SDK folder (C:\Program Files (x86)\Emotiv Research Edition SDK_v1.0.0.5-PREMIUM) as required.
What is the reason for this and how can it be fixed?
toncho11
Re: Error on PATH when connecting Emotiv
Post by toncho11 »
Check if the path to Emotiv if it actually contains the dlls EDK.dll, etc.
Enter the dos name of the path: "Program Files" expands to PROGRA~1 and "Program Files (x86)" expands to PROGRA~2
You should enter the path in: my computer -> properties -> advance -> Environment variables -> system -> "path"
-Anton,
Gipsa-lab
