Hi everyone!
I'm using OpenVibe 3.1.0 on Windows 10.
I'm following this tutorial http://openvibe.inria.fr/steady-state-v ... otentials/
I set up the Acquisition Server with a generic oscillator.
The problem is the following:
In "ssvep-bci-1-ssvep-configuration" i changed parameters (colours, frequency, etc.) in the box "experiment settings".
When i run "ssvep-bci-2-training-acquisition" i can't see my configuration but the predefined one.
Where am I doing wrong?
Thank you!
Greetings,
Simone.
Problems with SSVEP-demo configuration
Re: Problems with SSVEP-demo configuration
solved by changing parameters directly in the file openvibe-ssvep-demo.config and not using the designer.
This file is located in the following path C:\...\openvibe-3.1.0-64bit\share\openvibe\applications\ssvep-demo
