Hi, I'm not suure where to post bug reports but the Epoch driver sometimes hangs with this message, and the aquisition server needs to be restarted to get it working again.
[WARNING] After 1.022 seconds, theorical samples per second does not match real
samples per second
[WARNING] Received : 260 (0x104) samples
[WARNING] Should have received : 131 (0x83) samples
[WARNING] Drift was : 129 (0x81) samples (49.61%)
[WARNING] Added : 0 (0x0) samples (0%)
[WARNING] Removed : 129 (0x81) samples (49.61%)
[WARNING] The driver obviously tried to correct this difference
[WARNING] Please submit a bug report (including the acquisition server log fil
e or at least this complete message) for the driver you are using
[ INF ] Disconnecting.
[ INF ] Application terminated, releasing allocated objects
Bug report: Epoch driver hangs and quits
Re: Bug report: Epoch driver hangs and quits
Dear juxachim,
did you disconnect the acquisition server manually or did it self-disconnect ?
- If you did disconnect it, then the estimation of the drift is not reliable on such small amount of time (and we probably should check this before sending warning messages )
- If the Acq Server self-disconnected, then the reason is to be investigated. Still the amount of time for reliable drift estimation is not reached.
