Driver compilation
Lorena
Driver compilation
Post by Lorena »
Hello all,
Does anyone know if I can use Visual Studio 2010 in order to compile my driver for OpenVibe?
Thanks!
Lorena
Re: Driver compilation
Hi Lorena,
we're currently reworking the build system. The new system will allow much better Visual Studio 2010 support. We're almost done with it, but to be on the safe side, we won't include it in the next release (which is likely due next week). However, soon after the release, I will commit our changes to the SVN and you can checkout them from there.
After the change, OpenViBE can be more naturally developed using Visual Studio. Afaik this includes the drivers, as long as you're referring to those that are compiled and linked with the acquisition server.
Lorena
Post by Lorena »
Thanks Jussi,
So, which compiler should I use for the drivers right now? This is for Win 7
Lorena
Dear Lorena,
Visual C++ 2010 Express edition should be OK
Lorena
Post by Lorena »
Ok, thanks Yann, I will try then :)
Lorena
