Emotiv EPOC driver status
Rapten
Re: Emotiv EPOC driver status
Post by Rapten »
I've have Emotiv Research Edition SDK v1.0.0.4-PREMIUM and the data displaying is still a problem.
I tried filtering and everything else but no success. when i try writing it in a CSV format the file contains the header and rest of it filled with -1.#QNAN0;. Any suggestions ?? :(
lbonnet
Post by lbonnet »
Hi !
Is it normal to get warnings during compilation about conversion from double to float and possible data loss?
Yes. The headset produces float64 values converted in float32. The (static) cast is safe, so it shouldn't be a problem.
The headset works with the Emotiv software. No problems with the Expressiv suite.
Ok...
Yes, that's the point. OpenViBE somehow receives wrong values. Not A Number values.
I just updated the emotiv driver. Please update your SVN repository, and rebuild the software.
I added some error checking/logging, plus debug messages.
In your configuration file (C:\Users\login\openvibe.conf or C:\Document And Settings\login\openvibe.conf), please add the following line :
Kernel_MainLogLevel = Debug
And don't forget a linefeed at the end :)
If the file does not exist, please create it.
Then run the Acquisition-server, and use the Emotiv driver for some times (10-20 seconds).
You will see many messages in the console (Trace, Debug messages), e.g. drift correction messages. Don't pay attention to it :)
Stop the driver, disconnect it, exit the acquisition server.
Go in [openvibe]\dist\log. There should be a file named openvibe-acquisition-server.log.
Please send me that log file (attach to a post, or by private message... your choice), and I will check if the values sent by the Emotiv Engine are good or not, or if the API calls failed somehow.
Cheer up ! We will solve this !!
Rapten
Post by Rapten »
(180.89 KiB) Downloaded 303 times
here is the log file. i had to shrink the size of this log file to fit to the upload limit.
Am i getting any data ?
lbonnet
Post by lbonnet »
Thanks Rapten for the log,
The log messages in your file do not match the new massages I put in the code.
I assume you didn't update your SVN repository and/or re-compile the software ?
Rapten
Post by Rapten »
Hi Laurent,
I've updated the trunk and rebuilt the entire program. here is the new log file:
(17.41 KiB) Downloaded 300 times
I could see improvement in the updated version and wanted to know if you could figure out any thing from this log file. :)
here's a snapshot
No visualization.JPG (93.21 KiB) Viewed 14493 times
as you can see the raw signals are visible now both the visualizations are not responding. what could be the problem..
regards.
jlegeny
Post by jlegeny »
Hello Rapten,
could you please show us the scenario which you are using ? In order for the map signal displays to work they have to have positions of the electrodes. You can find examples of scenarios using these displays in dist/share/openvibe-scenarios/box-tutorials
Mikas
Post by Mikas »
Hi everyone
I still have problem with driver installation. After executed win32-build.cmd, I got "Install complete" message as in the attach picture, but for the last procedure when I looked in dist directory, there are no openvibe-acquisition-server.cmb file and when executed acquisition server there are still no emotiv on the list
I'm using Windows XP + VC++ 2008 and Emotiv Research Edition SDK_v1.0.0.4
Thanks in advance
lbonnet
Post by lbonnet »
Hello Mikas !
From the log you attached I can see that you are trying to build a branch in the acquisition server named wip-lbonnet-emotiv.
This branch was the work-in-progress version of the driver and has been removed on the 13th of September 2010.
Please take the latest version of the SVN, and follow the installation instructions.
As you are using Emotiv Research Edition SDK_v1.0.0.4 and the default configuration search for SDK v1.0.0.3, you may have to change the path where the build script looks at, as stated in the FAQ.
Open cmake-modules/FindThirdPartyEmotivAPI.cmake. Modify the FIND_PATH call with your actual path to the emotiv SDK.
This line (a bit explained here):
FIND_PATH(PATH_EmotivAPI edk.h  PATHS
    # for windows XP:
    "C:/Program Files/Emotiv/Emotiv Development Kit_v1.0.0.3-PREMIUM"
    "C:/Program Files/Emotiv Development Kit_v1.0.0.3-PREMIUM"
    "C:/Program Files/Emotiv/Emotiv Development Kit_v1.0.0.3-PREMIUM/doc/examples/include"
    "C:/Program Files/Emotiv Development Kit_v1.0.0.3-PREMIUM/doc/examples/include"
    # for windows 7 64b:
    "C:/Program Files (x86)/Emotiv/Emotiv Development Kit_v1.0.0.3-PREMIUM"
    "C:/Program Files (x86)/Emotiv Development Kit_v1.0.0.3-PREMIUM"
    "C:/Program Files (x86)/Emotiv/Emotiv Development Kit_v1.0.0.3-PREMIUM/doc/examples/include"
    "C:/Program Files (x86)/Emotiv Development Kit_v1.0.0.3-PREMIUM/doc/examples/include"
    $ENV{OpenViBE_dependencies})
should be modified by adding the path to your Emotiv SDK in the same way. For example:
    "C:\Program Files\Emotiv Research Edition SDK_v1.0.0.4-PREMIUM"
    "C:\Program Files\Emotiv Research Edition SDK_v1.0.0.4-PREMIUM/doc/examples/include"
hope this helps.
etwas
Post by etwas »
Any Emotiv EPOC driver news with developer SDK?
I try to work with OpenViBE and the SDK....let me know any solutions for it ASAP.
thanks!!
lbonnet
Post by lbonnet »
Hi etwas,
The developer SDK does not give access to the raw EEG data coming from the headset.
Only the Research SDK (and superior versions) allows that for the moment.
The OpenViBE driver for Emotiv EPOC has been developed and released officially after some discussion with Emotiv staff.
It's only compatible with the Research SDK, and on our side we don't expect any change in near future.
Rodel
Post by Rodel »
Hi everybody,
this is my first post in the topic. I've read all posts before, but I've got doubts.
I'm student and freelance developer. I adquired the developer license of EPOC Emotiv, version 1.0.0.0. I would like to know if somebody could send me the driver that all of you say works perfectly, or how can I get it.
In my system, I configure the adquisition server with my driver and when I make a click over "Play", the system cracks with the message "OpenViBE-adquisition-server-dynamic.exe left works".
Thanks in advance and sorry for my improved english ;)
Greetings,
Rodel (jmrodel.zero@gmail.com)
PS: If would be possible, I'd appreciate if somebody could give me some instructions (links) to make the driver (I don't know how difficult could be).
jlegeny
Post by jlegeny »
Hello Rodel,
in order to capture the raw EEG from the Emotiv EPOC headset (which is necessary in order to use OpenViBE with this headset) you will need to have the Research Edition of the SDK.
omid20d100
Post by omid20d100 »
Hi everybody,
how can i edit "electrode localization file reader" for Emotiv Epoc?
does anyone do this?
please help me.
Hello omid20d100,
This box is not specific to the cap/device you are using. Actually none of the OpenViBE boxes are specific to the cap/device you are using. However, this box uses a text datafile with a list of electrodes localisation. So depending on what you want to achieve, you can either look at the source code of the box in openvibe-plugins/file-io/trunc/src or edit the text file with electrode information !
toncho11
Post by toncho11 »
There is an official Linux research kit from Emotiv now!
http://emotiv.com/forum/forum3/topic2295/#message13452
I was able to download it.
We need to write an OpenVibe driver for it though.
It works. I could acquire raw signal on Linux. It also comes with some code samples that can be used for building a driver I believe.
-Anton
