Hi Thomas,
Thanks for the help. As I have KT88-2400 I can confirm that there are 26channels available, and these two additional are PG1 and PG2 (nasopharyngeal electrodes), nowadays rarely used. In a certain type of montage setting, they do appear though in the official software.
How did you get the information about the reserved bit at the beginning of each sequence?
The data format is a nightmare, it took me weeks to figure it out. Finally, I did some calculations and then everything fitted perfectly, so I am pretty confident about it. The reserved bit has to be there because of the "0xA0" marker, and I confirmed it by spoofing serial communication and saturating amplifier, so I obtained a series of 7fs in 45bytes chunks.
But, that is not the end, I managed to implement bit shifting and masking in python, but then I realized that it is even worse than I thought. As in KT88-1600, the two consecutive bytes have to be swapped, to make it work.
// Each channel value is formed by two consecutive bytes, the first byte is
// the least significant one and the second the most significant one. That means
// we need to write both bytes into a 16 bit unsigned integer and swap its byte
// order
Comment from KT88-1600 driver
https://github.com/miladinovic/KT88-160 ... ecKT88.cpp
This is the provisional decoding script I made tonight. It contains also a stream of data registered from the amplifier. The ECG is clearly visible on the last channel, but I don't know about the other channels if it decodes it properly. I will check it out tomorrow.
Code: Select all
import io
file_object = open('/tmp/eeg.txt', 'w+')
def swap_bytes(b):
bt=bytearray(b)
a=bt[0]<<4 | (bt[1] & 0xF)
bt[0]=bt[1]>>4
bt[1]=a
for i in range(2,44,2):
a=bt[i]
bt[i]=bt[i+1]
bt[i+1]=a
return int.from_bytes(bt, byteorder='big')
def remove_bit(num, i):
mask = num >> (i + 1)
mask = mask << i
right = ((1 << i) - 1) & num
return mask | right
def insert_mult_bits(num, bits, len, i):
mask = num >> i
mask = (mask << len) | bits
mask = mask << i
return right | mask
def decode_data(b):
sample=swap_bytes(b)
#remove unused bits
corr=0;
for i in range(7, sample.bit_length(), 8):
sample=remove_bit(sample,i-corr);
corr=corr+1;
#add HSB to make 2byte representation
corr=0;
for i in range(12,sample.bit_length(),12):
sample=insert_mult_bits(sample,0,4,i+corr)
corr=corr+4;
#convert to bytes 26channels x 2 bytes, bigendian
bt=sample.to_bytes(26*2,'big');
#assign the result to int list
idx=0;
out=[];
for i in range(0,26*2-1,2):
out.append(int(int((bt[i]<<8 | bt[i+1]))))
idx=idx+1;
#print the values
print(','.join(str(item) for item in out))
file_object.write(','.join(str(item) for item in out)+'\n')
if __name__ == '__main__':
b= b'\xa0\x02vBy\x16\x103\x166V\x02J(\x12n\x19/\x0f9:pw\x0c~)\x03M\x18Gn\x08RG\x06|ZX\x7ftzs1\x06]i' \
+ b"\xa0\x06t\x07OT]Wh\x00i=v\x19\x17T\x19\x0cr\nN'y3\x11\t]h\x1a\x13F\x1a7\x1f%[eX\x0c\x7fx\x02+\x07-\x08" \
+ b'\xa0\rJ,\x10y\x1aFX.\x13e63J>3ou#O0s\x1c93m"3wo#$z,j\x13H!(\x07\x03-\x08FM' \
+ b'\xa0\t-Ry]^\x1fv&<\n>\t7x\tq\x06\x18eO*(q\x19D/\x08\n\\)a \x16IWv^s\x05r \t*T' \
+ b'\xa0\x02g\nY\x1f\x103\x03\x0fFFQ)\x0f\r\x19=39\x17\x05hv*)\x17`\x19N\x07\x08\x00b\x06\x179XZmzw;\x06_f' \
+ b'\xa0\x02t&MT\\W^}i%z\x19<d\x1a!\x02\n\x1d+id0\x19\x0ed\x1a\x15C\x1a\\)%fdY\x06\x03x\x04/\x07/\x0c' \
+ b'\xa0\rJ\x0c\x10y\x1cFoG\x13\\\x163R53du#\r2s\x7f93h\x143[g#,w,h&H#0w~*\x08FM' \
+ b'\xa0\t-\x13i]^\x1fbQ<\x17+\t\x14`\x089r\x187R+*\x00\x19)%\x08eP)G\x1b\x16Ccvs~\x05v\x11\t+W' \
+ b'\xa0\x02\x7ff{V\x103D1Fz"\x18cY\x19\x0c\x02)uWg\x0fr\x19t2\x18(W\x08K1\x06j{X\x17szu8\x06]i' \
+ b'\xa0\x06v\x06M\x14]Wn>iq\x07\x194g\x1a%\x18\n=Cy\x13Q\x19By\x1aL`\x1a\x7fC%}XXttx\x01,\x07.\x08' \
+ b"\xa0\x0fK,\x02y\x1cF\x03o\x13/I3s>3wy#S+s#z3$,C\x13t#j|,k'H0'w}.\x08FQ" \
+ b"\xa0\t}\x12Y\\^\x1fjR<5u\tk%\t\x1c:\x18tq+-[\x19ko\t*\x0b9\x15M\x16pdv}}\x05n\x10\t'X" \
+ b'\xa0\x02\x7f\x07{V\x103\x01\x0fF46\x18cO\x18\x16|)eThU\x1e\x19R;\x18\t[\x08)/\x06arX\x11vzuC\x06^h' \
+ b'\xa0\x02=#_\x14]W;sYmV\tb8\x19oW\nl\x13i0\x11\t\rN\n41\x1a\x16\x0f%GlX}}x\x089\x07/\t' \
+ b'\xa0\rJ\x0c\x10y\x1aFoH\x13J\x163\x0b\x1939L#\x05\x0bsG\x0c3\x14\x003%Q#$U,J:H>)\x07\x02#\x08EV' \
+ b'\xa0\t-ri\\^\x1fI6<\x1f:\t&z\tF\x02\x18dd\x1axf\x19\x1dM\x08t\x7f9\x072\x16^SvB\x7f\x05w\x0f\t)Z' \
+ b'\xa0\x02\x7fF{\x16\x113\x1c\x0eFf/\x18dd\x19\x07\x03){egc^\x19_H\x18\x17p\x08W@\x06oaXs\x00zsF\x06]n' \
+ b'\xa0\x06v&I\x14]We+i6\x18\x19Dl\x1a\x1e\x1a\nPMiw0\x1a\r\x0c\x1a\x18o\x1avH%wOXh}x\n&\x07,\x0f' \
+ b'\xa0\x0fK,\x10y\x1aF-Z\x13(+3Q+3Zq#?&sR03j$3rn#Es,\\8H<"\x07\x05+\x08FZ' \
+ b'\xa0\t}\x1eY\\V\x1fk<<?Y\tZ\x0f\t\x0c7\x18$\x0b+m\x1c\x19]~\t6\x179\x06P\x16lMvXy\x05p~\t(\\' \
+ b'\xa0\x02>g{F\x113a\x18V\x1f\x03\x18F6\x18qe)r;g)G\x19F\x1b\x18\x0f;\x08(\r\x07<$XR\x04zn:\x06\\j' \
+ b'\xa0\x06v&k\x1c]WO[i%\x1b\x19/x\x1a72\n[hi}\\\n{\x1d\x1a4\x03\x1an^%\x0b<Xexx\x06\x1d\x07-\x0c' \
+ b'\xa0\x0bJ,\x10y\x1cG!\x14\x13f[3:43Ie#I\x18s\x19]3J\x183tX#Ub,M>HJ$w\x7f\x1e\x08F]' \
+ b"\xa0\tv\x1e]\\^\x1fb2<o\x15\x19\x01@\t\x18R\x18[,+]T\x19\x7f\x02\t^%9.q\x16\x7f%v0}\x05g\x10\t'\\" \
+ b'\xa0\x06?c{F\x112_JFq"\x18S6\x18mb9\x00?g"f\x19R\x1b\x18\x0f8\x08 \x16\x07=\x18X>\x05zkI\x06\\j' \
+ b'\xa0\x02v\x06i\x1c]WipiL\x18\x19*t\x1a/-\n\\hy4W\x1a\x15\x13\x1a\x0f\x03\x1ame%\x08BX_yx\r\x11\x07,\n' \
+ b'\xa0\x0fK,\x14y\x1aF6E\x13%B3&\x173FN#4\x07sU<2m}3^H#0U,>GHH#\x07\t\x0b\x08Fa' \
+ b"\xa0\t|\x1e[\\^\x1f8 <[q\t[\x1e\t\x17E\x18\x19)+P8\x19 o\t_*9\x0fm\x16z\x1dv\x1fy\x05o\x06\t'V" \
+ b'\xa0\x06=g{F\x112\\XFAt\x18,#\x18[R)01g\x10E\x19=\x06\x18\x110\x08\x0c\x06\x072$Xe\rzkY\x06\\l' \
+ b'\xa0\x06v\x06i\x1d]WR+i+\x0b\x19Nz\x1aQC\nA|y.h\x1a\x19+\x1a[\x16\x1a\x05q%\x1c2XYqx\x00\x15\x07-\x06' \
+ b'\xa0\x0bK,\x10y\x1cGM\x14\x13*>32\x1c3?S#&\x04sVY3A\x103YN#RR,=XHg\x19w\x7f\t\x08D^' \
+ b"\xa0\t~\x1e]V^\x1f+D<\x7f\x07\tt>\t\x1fe\x18(?+hl\x19M\x1c\t@H9'\x00&\x0f v\x1au\x05t\x06\t'W" \
+ b'\xa0\x06=g+G\x112+hFKp\x186#\x18XW)K6g\x1eW\x19*\x0f\x18k3xw\x08\x07/!X+\x06zxW\x06\\i' \
+ b'\xa0\x06f&i\x1c]W\x0f\x1ei\x00\x07\x1a4\x04\x1a:0\n)gizq\x1a\x0e\x18\x1a\x1d\r\x1akd%\x108X6vx\x0f\x16\x07-\x06' \
+ b'\xa0\x0bK \x10y\x1aG "\x13\x10=3\x11#30N#uss\x1fp3M\x043II#/P,@dHp\x1c\x07\x10\x16\x08Da' \
+ b'\xa0\t~^_V^\x1f\x1aZ<`\x1b\ti]\t\x1dy\x18"/+2\x10\x19\x16$\tPY9"\x15&\'0v@y\x05v\x08\t&W' \
+ b'\xa0\x06?Go\x04\x112||F9\x05\x18"\x18\x18HN)\'\x19gcQ\x18\x1fy\x18f&\x08\x07y\x07 Ph\x1e\x15zg[\x06\\k' \
+ b"\xa0\x06gni\x1f]W\x18[YZ5\x1aT\x1b\x1an]\n>\x1aiR\x1f\x1a\x19S\x1aN@\x1a\x13\x18%9\x00X'yx\x05\x0b\x07,\x07" \
+ b'\xa0\x0bK$\x10y\x1aGC$\x13\t43,\x123AI#\x0bvs\x1fJ3J\x043cC#TB,5`Hl&\x07\x07\x1c\x08E^' \
+ b"\xa0\tt\x1e_T^\x1f-<<ie\x19\x18&\t>X\x18,\x16+?R\x19\x1d\x0e\tv49A[&\x055v\x19x\x05t\x15\t'W" \
+ b'\xa0\x06-\x0f\x0fI\x112~CFX\x1d\x18\'c\x18@!("zg\x7fo\x18"Y\x18j~xgKw}]Xv\x0ezlY\x06[m' \
+ b'\xa0\x06f&i\x1c]W/\x19i\x01\x03\x1ai\x0f\x1aN6\nUoiw;\x1a2\x1d\x1aE\x16\x1a|l%\x1d0X2rx\x17\x12\x07,\x04' \
+ b'\xa0\x0bJ$\x14y\x1aGB\x1d\x13u\x173\x1e\x0c3*=#\x11os\x04,2Bl3O<#>8,4mHx\x1f\x07\r\x0f\x08Ff' \
+ b'\xa0\x0bv\x1f_\x06^\x0fiI<O\x03\x19\x13Q\t]\x0b\x18Yj+\x13{\x19&0\tzy9H\x1f&?|vos\x05p\x05\t%W' \
+ b'\xa0\x04-G/\t\x11B\x02nFRG\x18\x00d\x184!)\x0c\x04g|1\x18\x00V\x18X\x01xcNw\x7f`h\x19\x18zci\x06[l' \
+ b"\xa0\x02gNi\x1f]X2\nYrD\x1af.\x1aob\nY!y)7\x1aFT\x1ag@\x1a#\x12%?\rX'mx\x12\x01\x07-\x03" \
+ b'\xa0\x0bJ$\x149\x1aG[j\x13vs3\x16\x1b3"A#\r_sOt2R~3U-#[4,/vX\x11\x1c\x07\x0f\x1c\x08Ek' \
+ b'\xa0\tv_O\x16^\x1f\x0c=<KO\x19Dp\tr\x19\x18zW+[\x13\x19U9\x19Fb9|&&A\x03v{p\x05g\t\t$W' \
+ b'\xa0\x04%\x0e\r\x19\x11B\x1b4FwP\x18{9\x18$|(\x14`gzl\x18}1\x18daxJ*wS\th(\x16zdd\x06Zn' \
+ b'\xa0\x06.\ny\x1fUW\x18\x0bi+%\x1a\x00%*\x05P\x1a \x18y\x15~\x1aWC\x1a ;\x1a\x0e\x08%3\x0fX\x0efx\x12}\x07.\x01' \
+ b'\xa0\x0bK$\x14)\x1aGm\t\x13\x19\x1d3\x16\x023\x15##*PsPJ2<c3_\x1d#5\x19-\x17\x08X!\x13\x07\x0c\x17\x08Cf' \
+ b'\xa0\tv[_V^\x1f\x0f/<(\x1b\x192Z\tV\x00(\x00Q+7\x12\x19?<\t\x7f]9]\x12&=\x01v\x04o\x05o\x12\t%U' \
+ b"\xa0\x04%\x0e\r\t\x11BL$FI'\x18k9\x18\x0fy(\n_gza\x18l9\x18#[xB/wU{h/\x14z_m\x06Zl" \
+ b'\xa0\x06.\ni\x1f\x15Wa\x08iA(\x1a\x1e4*\x14`\x1a!\x19y@g\x1a\\C\x1a_9\x1a4\x16%?\x08X\x05hx\t{\x07-\x7f' \
+ b'\xa0\tK$\x14)\x1aW,\x13\x13_@31\t3-2#4Rso\x1e2Ib3<$#k%-+\x13X,\x1b\x07\x0e\x11\x08Do' \
+ b'\xa0\x0b&so\x0f^\x0f]!<fV\x1ax(\x198U)02+\x12-\x19e\x7f\x19\x1eN9\x11s&\x1c0v4i\x05s\x05\t!W' \
+ b'\xa0\x04%*\r\x19\x11B\x10\x19FP\x0f\x18e\x1c\x18\x08](lXg,W\x18I)\x18\x08Qx$\x17w=\x12h<!zbu\x06Yn' \
+ b'\xa0\x04.Ni\x0f\x1dWj*i\x0c&\x1a\x109*\x03b\nr.y<$\x1a0Y\x1a F\x1a\x01\x1b%?uX\x03mx\x0f\x06\x07.{' \
+ b'\xa0\x0b\x1b \x04)\x1aGf\x17\x13R42\n\x7f3y\x19#s:sZU2\x0e]3\x7f\x04#\x1a\x0e-\r\x16X?\x13\x07\r\x08\x08Cv' \
+ b'\xa0\x0bfS\x7f\x0e^\x0f2"<[V\x1aO(\tsF)\x06\x19+(D\x192s\tj&9Ui&\x00&v5p\x05n\x0f\t![' \
+ b"\xa0\x04%\n\r\x19\x11B.\x1fFt\x0f\x18Y6\x18\x00{(R^gCk\x18O1\x18\x0b`x\x19*wS\th:'z[i\x06Zr" \
+ b'\xa0\x06.oyNUW\x1e\x07i1,\x1a\x1bY*$\x06\nc5i{\r\x1aIb\x1a\r^\x1au0%\\cHKdx\x14w\x07.\x04' \
+ b'\xa0\t\x13 4"\x1aW\x1d\x1a\x13?\x1f2kr3q\x0e#N*s"\x1c2\x0bD2=z"v~-z"X/\x11\x07\x12\x03\x08Dx' \
+ b'\xa0\x0bv_o\x06^\x0fv\x13<F0\x19<u\t] \x18vx++\x15\x19EJ\x19,\x009I9&MSv#l\x05o\x04\t%U' \
+ b'\xa0\x00w\n\t\x1a\x11BtyEbs\x17+i\x08O0(C$ge \x186v\x18\x07\x1fwnlw\x037hV\x1czXj\x06Yt' \
+ b"\xa0\x06.Ny_\x15W?\x19i\x13'\x1a\x0eC*\x0fh\ny!y+\x02\x1aZO\x1a\x04H\x1a\n\x16%>\x03Hwax\x0fn\x07.~" \
+ b"\xa0\tK \x14)RW#,\x13+\x1c3\x04\x083\x04%#l8sA52'P3;\x0f#@\x10-\x19\x1aXD\x11\x07\x0f{\x08D\x04" \
+ b'\xa0\x0b&Wo\x0f^\x0f1\x1a<\x118\x1aa(\x19\x1cT\x19t#+-E\x19Wp\x19:<9\x15l&\x12\x19v\x04q\x05g\x10\t"b' \
+ b"\xa0\x04w\n\x1d\x1a\x19B\x11\x04E\x1eZ\x17<{\x08\\=(\x1c:g'2\x183\x06\x08l2w~|w\x1a\x11h)%zY\x04\x06Yv" \
+ b'\xa0\x04.NiO\x1dW{Ti\x021\x1a\x06G*\x04g\nI)y\x11\x11\x1aOW\x1aEJ\x1a\x19\x1b%EvHrdx\x11\x01\x07.\x7f' \
+ b'\xa0\t\x12 4)\x12W)}#\x00O2s{3n\t#o$stB2/X2!y#\\\x00-\n6Xk\x0b\x07\x16w\x08Ew' \
+ b'\xa0\x0b&Si\r^\x0fZ]<u|\x1avD\x199])L7+ph*\x01(\x19MM:E\x01&+0v@e\x05o\x03\t"V' \
+ b'\xa0\x04t*\r\x1b\x19Bd8V\x14\n\x17\x1dl\x08T\'(A+g\tU\x18!\x04\x18\x08"w\row\t*hr\'z\\\x01\x06Yp' \
+ b'\xa0\x06.KyO\x15W\x10Yi.I\x1a,p*<\r\x1a\x10MydS\x1aP~\x1aLr\x1ai=%iWHg\\x\x0en\x07,x' \
+ b"\xa0\t\x1b \x14)\x1aW'[\x13x'2\x06z3|\x18#l3s}L2\nP3V\x06#l\x05-\x0f'XY\n\x07\x13\x02\x08F|" \
+ b'\xa0\x0b.Sy_^\x0f\x19\x1e<h^\x1a\x192\x19=Z)7E+vM*\x06\x0b\x19\x01R96|%\x1b|ftf\x05p\n\t!O' \
+ b'\xa0\x00wG;R\x11BO}E}W\x17\x0f8\x07#w\x18}~f9\x7f\x08\x7fM\x07ZtwI>wXKh\x07*zaz\x06Yp' \
+ b'\xa0\x04.oiN\x15WS=i$V\x1a${*1\x0f\neVii>\x1ahu\x1axw\x1af=%hOHc_x\x1cj\x07.p' \
+ b'\xa0\t\x13 4c\x12W\x17R\x13jQ2kr3`\x02#p\x17sCX22<2/s"\x11l-zMX\x06\x08\x07\x15s\x08E}' \
+ b'\xa0\t,\x12i\r^\x0fz#=>\x0e\x1a$k\x1aA\t)f`,i\n*Q)\x19}w:!\x18&:\x19v\x0fb\x05m\x07\t Q' \
+ b'\xa0\x00~#9R\x11B>mU\x0f]\x07w9\x07\x12r(\x15{g\r/\x18\nI\x07Bqw49wKQh\r1zZ|\x06Xo' \
+ b'\xa0\x04.KkO\x15W\\1i8:\x1aCi*(\x04\x1a)?yKD\x1a(\\\x1az^\x1a\x1a4%Q]HW^x\x15k\x07/r' \
+ b'\xa0\t\x1a\x1d4cRW<k#\r22\x01n2Xy"\t\x7f\x03\x01K2<)2\x19a"<k-rLX\x01\r\x07\x14{\x08E\x01' \
+ b'\xa0\x0b<\x12I]V\x0f\x00R=D\x10\x1a4\x07\x1aY\x1b)sb,_\x14*=1\x1al\x02:H=%Tkfoi\x05k\x7f\t R' \
+ b'\xa0\x04~\x03;R\x19Bj+U\x12X\x07o+\x07\x0bb(\rcg\x7f\x03\x08v8\x07E^w5/wCah\x1f6zS\x03\x06Wy' \
+ b'\xa0\x04>K_O\x15WQJi\x16O\x1a@\x0f*_,\x1a\x0ekyZ;\x1a\x11\x10\x1b\x1e\x08\x1a$T%x*H\x1a[x\x16b\x07/s' \
+ b'\xa0\t\x03\x104c\x12W/m\x13\x7f63s\x013k\x12#P\x10\x03\x17C2/G2*h"<e-xLX\n\x10\x07\x18v\x08Dz' \
+ b'\xa0\t.\x12iMV\x0f\x7f\x10<6v\x1aHo\x1aU\x19)I`,}\x00*D7\x19on:9\x14&D\x04fri\x05lt\t E' \
+ b'\xa0\x00>G;RYB}aU\x1f3\x07q\x13\x07\x7fU\x18Xbfy\x7f\x08\\3\x07&Uw\x19\x1ew2`h15zW\x02\x06X\x05' \
+ b'\xa0\x06?O}OUW\x1fei\x0e^\x1aW\x02*G\x1d\nf_ySS\x1aY\x00\x1a\x00{\x1a/F%pIHeZx\x17h\x070Z' \
+ b'\xa0\r\x12\x194c\x12Ww\x12#xV2~Z2Xp"c|\x03\x07H2\x12+2.Q"]X-fgX0\x00\x07\x19s\tDC' \
+ b"\xa0\x0b,\x12y]^\x0f\x05'=z\x17\x1a6j\x1aY\x0e){d,U\x01*D7\x19$h:P*%G}fug\x05j\x01\n\x1f|" \
+ b'\xa0\x02~C;RYB\x00]U(?\x07j\x1a\x07\x07\\(\x02`fRt\x08p2\x07iRw<#w9th&:z[\x07\x07Xz' \
+ b'\xa0\x04?k]GUW3\x04Y\x7fV\x1aN%*d4\x1a\x1dtiw4\x1a_\x14\x1bj\x14\x1a)`5\x0b"H\x10[x\x19P\x08/\'' \
+ b'\xa0\t\x12)6cZW*=#\x02#2RL2Kf"Hts+\x0e"]\x1b29R"%V-cZX\x1b\x0e\x07\x16\x02\x08G\x1c' \
+ b'\xa0\t,\x1eY]^\x0f#\x0b=:%\x1aPx\x1a}!)\x08\x08,A\x07* L\x1a/\x14:GL%n9f*d\x05h\x05\x08\x1f3' \
+ b'\xa0\x00.G?@\x19Bp]U)5\x07B`\x07N\x1d\x18]*fbJ\x07&y\x07\x10\x1ew\x00nx\x01\x0chF4zS\x13\x05W\x1a' \
+ b'\xa0\x04>K]G\x15WNNiD\x7f\x1a>&*V7\x1a\x03ey.U\x1aX\x01\x1b\x11\x11\x1a!Z5\x00)H,Qx\x18Y\x06/\x0c' \
+ b'\xa0\r\x12)6c\x12Wj\x08#$F2?Q2Jd"6esTB"_\x132\rM"\x1dJ-TlX@\x03\x07\x1eg\x07E\x7f' \
+ b'\xa0\t$\x12I]\x1e\x0fS,=\x1d\x08\x1ayn\x1aj\x1f)Oh,\x1e\n*\x077\x1av\n:+/%N]fZf\x05l\x10\t \x1b' \
+ b"\xa0\x02/G?A\x19B\x17~E{\x19\x07\x17b\x07U#\x18%'f;H\x07\x1ay\x07\x07\x1fgtnx\x06\x14hs7zR\x01\x06X\x0b" \
+ b'\xa0\x00~K_G\x15Xu\x1ei5~\x1aP-*\x08I\x1a\x1e{yhp\x1a\x10\x11\x1bB\x16\x1aXi5\x0e/HQOx\x1fM\x0711' \
+ b'\xa0\x0f\x12\x194bRW\x1bH#8i2pc2mh"of\x030p20 2OG2\rS-g{X^\x06\x07\x15d\x08F\x02' \
+ b'\xa0\tt\x1e[VV\x0f_"=\x0fL*\x17F\x1aTU)C8,~^*)w\x1as>J>\x065\x1c.f.f\x05hv\t\x1cN' \
+ b'\xa0\x02/G?HYB\x148Ek\x14\x076\\\x07Y\x0c\x18U+fXU\x07N\x7f\x07$ w\x04ph{\x06hDCzP\x12\x06X\x04' \
+ b"\xa0\x04>K_G\x15WT2i\x1bk\x1aP6*gD\x1a\x13}y'N\x1a\t\x15\x1b,\x14\x1a\x18\\5\x08*H*Sx\x15W\x072x" \
+ b'\xa0\r\x12)6sRWn7#0H2F_2*`"M[st8"x\'2\x17;"5;-U\x02X]\x03\x07\x19`\x08C"' \
+ b'\xa0\t<\x1e]UV\x0fG9=\x1b8\x1aR2\x1a{F)2),@1*I\x02\x1aN-:p_5\x02EfBc\x05j|\t\x1dl' \
+ b"\xa0\x02'F\x0f\tYB<fEr\x16\x07}D\x07\x17p\x18%\x0bf!-\x07\x01h\x07k}gQPh[\x1dx\x04DzM\x17\x06X\x12" \
+ b'\xa0\x04=C_UUW?jZL\t\x1aXB*pW\x1b\x0c\x1cy\x0ey\x1a\x0f;\x1b\x194\x1b\x11\r4)jH\x11Lx\x19F\x070\x05' \
+ b'\xa0\r\x13)&cRWx)\x13KL22[2 [",Ys9<"u(2zG"\x0eK-ccXY\x01\x07\x1b_\x08G7' \
+ b'\xa0\t}\x1e]GV\x0f\x10/-(e\x1a]o\x1a\x08z)\x15T,\x1dX*a)\x1ado:e"5Kvf\x1c`\x05dz\t\x1dn' \
+ b'\xa0\x02/G?IYB\x057EB\x11\x07\nK\x07\x17\x01\x18!\x1bf3:\x07\x14s\x07\x0e\x14gS_hh\x0eh\x7f>zI\x05\x06V\x1e' \
+ b'\xa0\x04>OYOUW\\\x05i\x17K\x1aK\x1a*b(\n|by>0\x1am~\x1b1\x04\x1a%H%k+H4Vx\x18L\x073\t' \
+ b'\xa0\x0b\x12\x190sSW\x1bu#]$2N-261";+\x03\n\x082\x05n2\x1b\x14"W\x12-\'\x15Wtx\x07 U\x08DD' \
+ b'\xa0\rt\x1e[TV\x0e!o=,**\x14A\x1aPW)D1,L\x1e* u\x1an=J*p5\x11\x17f\x0e\\\x05fs\t\x1dz' \
+ b"\xa0\x02$N\x0f\tYBA1U\x13i\x07r\x19\x07\nB\x17\x15_f'\x03\x07\n7\x07ySgD&h0>x\x1bCzH\x14\x06X*" \
+ b"\xa0\x04|COUUWXSj/\x15\x1at`*\x1e^\x1bK\x1by?e\x1a?,+ <\x1b'\x014,vH\x01Ex\x14L\x071\x14" \
+ b'\xa0\x0f\x12)4sSW/)#JL2GO24R"PEsz%2\n\x072O4"2--N\x07Wk{\x07\x1eR\x08GR' \
+ b'\xa0\tt\x1fOV\x1e\x0f.\x15=\x15j*\x0b\x7f\x1aK\x11)D[,QC*\x18+*+wJ\x10 5L\x04f\t^\x05f\x04\n\x1c\x01' \
+ b"\xa0\x02-\x0e\x1fIYB(&Ehm\x07\x0f5\x07\x1bg\x17\x10|f(u\x07\rW\x07\x1fqgG@hR#hyMzK'\x06X5" \
+ b'\xa0\x04wCOGUW*AYko*\x13S*\x1fg\x1b5\x12y)S\x1a+%+\x04/\x1a {5\x1e\nH\x15Kx\x1eO\x074\x19' \
+ b'\xa0\x0f\x12\x1923SW\x1b>#)D2:M2\x1dE"8/\x03\x16\x1d"z{2,\x15"+"-D\x1cg\n{\x07#]\x08Fb' \
+ b'\xa0\n|\x1fO\x07\x1e\x7fz\x17=\x05a\x1afx\x1a,\x06)@],kJ*\x11\x1a*\x05b:y25Mwf}]\x05g\x06\n\x1b\x10' \
+ b'\xa0\x02T\n\t\x03YBc-U\x1eT\x06\x15mw1\x0e\x17Q fo8\x07:y\x07@\x10f\x0bsh\x7fuxcSzG\x16\x06WC' \
+ b'\xa0\x04~C]GUW3Pi>|\x1a9D*\x08T\x1b\t\x01yS"\x1aX\x0f\x1b@\x18\x1a/z5\x1a\x1cH)Jx\x1cJ\x074,' \
+ b'\xa0\x0f\x13\x1963SW\x16V#\nf2Eb2<Y"U.\x03!\x08"\\\x0f2\x1b&"y/-O/g\x12u\x07&Y\x08Es' \
+ b'\xa0\t$;O\x16\x16\x0f\x0f$=Kg+R\x15*\x13#9\x10Y,\tC*;<*LxJp85P\x0ffj_\x05a~\n\x19 ' \
+ b"\xa0\x02D\n\r\tYBW7UGM\x07d\x15w}A\x17zUfVh\x07o6\x07eLgP%h'Kx&RzA\x1b\x06XS" \
+ b"\xa0\x04~G]EUWLxi\x14o\x1aeA*\th\x0bw\x17y=`\x1aw'\x1b+*\x1b'\n5\x1f\x14H\x1fFx\x16=\x076:" \
+ b'\xa0\x0b\x12\x19&3\x13X5\x04#jT2-12\t9"*-\x03$."]\x042z\x10"=%-6\x1dg\x1dl\x07\x1eM\tE\x0e' \
+ b'\xa0\ne\x17\x7f\x06\x16\x7f>1-b~+\x06\t\x1a-\x1e*^\x10,Qh*\x18S\x1aw\x04J\x17[5bJf\\^\x05bz\n\x1a8' \
+ b'\xa0\x02D\n\r\tYBI>U\x1ac\x078\x01w:$\x17n<fXc\x07X\x17\x07H.g\x1f\x11h\x14WxJXzD \x06Yr' \
+ b"\xa0\x06tBO\x15UGz7j'\n*\x00t+F\x17\x1b@:yam\x1aZ<+ T\x1bG24HhHoJx\x14;\x075P" \
+ b'\xa0\x0f\x12\x1903\x13W\x1d/#b/2/22\x1f2":\x1c\x03+\x0e2\x1ce22\x02"P\x14-$0g\x15r\x07\x1f]\tG(' \
+ b'\xa0\x0ee\x13o\x06\x1e~B\x7f-bg+K\x1f\x1aw!:\x02\x0f,_g*oA*`\x01JDV5\\Tf0]\x05^\x03\n\x1aM' \
+ b'\xa0\x02T\x0b\t\x03\x19BS*U\x075\x06,bv%|\x17O\x15f7;\x07Hh\x07K\x04f\x0eghkvxZUzD\x1c\x07X\x03' \
+ b'\xa0\x04uC_UUW\x1dzZ\\\r**c*5y\x1b_*yFd\x1ab"\x1b{;\x1b7\x1746xH\nAx 5\x074\\' \
+ b'\xa0\x0b\x12\x19\x101\x13XU\t#?@2U 2\x12\x1f"\\\x08\x03H\x142\x1eX2(w"S|-\x1bLg>l\x07$E\tG4' \
+ b'\xa0\ne;o\x06\x1e\x7fd\x1d-Zf+a\x06\x1a|\x149\x1av,9k*e8*)\x03JGH5Wofg^\x05d\x03\n\x1aT' \
+ b'\xa0\x02U*\r\x0b\x19B}\x1dEt<\x06SkwV\x0f\x17r*f.U\x07c\x04\x07E#f$zh\x02pxD]z@+\x07W\x05' \
+ b'\xa0\x04uc_EUW\x1aKZo\x01*\x0bb*)y\x1b )y"v\x1a0+\x1b@A\x1b/\x135,\x03H\x02Cx\x18D\x075^' \
+ b'\xa0\x0f\x12\x19"3\x13W4m#:a2\x1f,2\x05&""\x11\x03GI"ek2W\x06"L\x07--3g=m\x07 I\tI<' \
+ b'\xa0\ngWo\x0c\x1e\x7f\x02\x02-.\x16+8/\x1a\x7fK*|=,g(*Nt*\x10@KH\x035\x18\x14f\x17Z\x05^\x02\n\x19P' \
+ b'\xa0\x00\x19\x0b1RYR\x02"Ek.vrSv}o\x17\x0c\x00f79\x07\x11_v~~f|Xhh\tx\x06[zC/\x06Y~' \
+ b'\xa0\x00}\x06_UUX\n\x06ZK\x14\x1att+(\x15\x0bt>z3\x0f\x1a\x110\x1b6I\x1b4.4EoH\t:x!3\x077P' \
+ b'\xa0\x0bR)\x023\x13X;"#\tV2\x10*"v\x1f"\x05\x13svC"7_2R{"7\x0c-!7gFo\x07&>\tI%' \
+ b'\xa0\x08fSo\x0c\x1e\x7fw\x17-y\x10+8C\x1abC:\x04I,\x1b#*\x1cr*"2K<\n5\r\'f\x15\\\x05a\x0b\n\x1a/' \
+ b'\xa0\x02T\x0b\t\x03YB`\x17U\x00*\x06\rav\x05|\x17J\x15f 2\x07\x19k\x07)\x08f\x07jhq}xs]zA>\x06Z^' \
+ b'\xa0\x04vBO\x15UW\x13Oi/v*(k+0\x16\x1bs9ygV\x1aN4+\x1dL\x1bX*4<kHr;x\x1f,\x078\x19' \
+ b'\xa0\x0fS\x11\x101\x13Wjv#\x0eI2( "v!"]t\x03C\x042\x08g2$t"{~-+HgRa\x07*B\tI\x02' \
+ b"\xa0\x0e'Ri\r\x16~\x12m-0\x1c+Pb+\x1d\x05:IZ,X\x0f;\x03'*I[K\x00*5L\x14f\x1bT\x05\\z\n\x17\x01" \
+ b'\xa0\x04Y\x0b)RYQ\rzEU\x1dvzSv\x01q\x17$\x03f\x17\x1e\x07"e\x06\x11{f|Uhj\rx\x07_z?/\x06Y2' \
+ b'\xa0\x06eBO\x15\x15Gv#Z_\r+\x0c\x03+J\x1f\x1baOy\x1e~\x1a>B+\x0b`\x1b 74VWHX=x\x1f$\x077q' \
+ b'\xa0\x0fR\x11\x021SW]`#m=2\x0c\x0f"k\x02"2n\x03\x053"RK2}e"+f-\x12Ygbo\x07#D\x08KR' \
+ b"\xa0\x0c'Sk\x0c^~wg-5\x14+b_*\x1fc:8U,6@+l\x11*SZK]\x1955\x1ef\x11T\x05^\x03\t\x19Z" \
+ b'\xa0\x02\x19#1RYBo\x0cEg\x0cv{Pv|f\x17\x1fwVz(\x07\x11UvwqfsKha\x19x\x0f^z:&\x06Z\x0b' \
+ b'\xa0\x06e\x02_U\x15Gs~Zq\x1f+\x12\x01+N%\x1b\x1cKz\x15\x07\x1a\x1c:\x1b\x13V\x1b274SeH\x02<x\x1c0\x079S' \
+ b'\xa0\x0b\x12\x11\x021SXi6#zl2\x1d\x1d2\t\x1f")s\x03\rK"`P2=c"jh-&ogxe\x07$1\x08J;' \
+ b"\xa0\n'ri\rV\x7f$\x04-u/+\x7fi+X\x11:Sd,\rR;\x19\x12*^TK\x18 5J@f0Z\x05]w\t\x17G" \
+ b'\xa0\x00T\x03)S\x19R;\x0cUR\x15\x06\x00Mv\x0bo\x173vfo1\x07#T\x06\x11nf\x10Fhd&x\x1fiz:.\x06\\\x7f' \
+ b'\xa0\x04d"MU\x15WHdjH\x1a+I\n+d,\x1boLz\x1a\x06*\x02H+*c\x1bc?4SfH\x06@x 2\x078A' \
+ b'\xa0\t\x13\x11\x100Sh1$#,i2L+2\x12\x1c"Vn\x03g(2\x1dl2/r2\x03~-2Xg~i\x07&9\x08J<' \
+ b'\xa0\x0e?Ry\rV~\x1e\\-06+\x1e\x07+e\x1d:_k,C5;0H*\x1dzK\x1fJ5g\x07f\x07T\x05\\l\t\x17A' \
+ b'\xa0\x04\x18\x072R\x19Q%|U\x04\x13vS6v[Q\x07nKf\x10\x08wvAv\x7fUfo1hMBx"fz<8\x06Z~' \
+ b'\xa0\x06e\x02_\x15\x15G[jZ_)+1\x03+iB\x1b(Yz(\r\x1a;V\x1bis\x1bTK4bYH^8x\x1f(\x079A' \
+ b'\xa0\x0bR\x11\x021SX`\x19#oc2\x17\x04"d\n"\x1bf\x03\x135"\\Z2Rc"]k-\x18Zgjc\x07,0\x08L;' \
+ b"\xa0\x0c'ZI]^~74-\x18*+~s+:':X\x12,=`;#V+c\x0cK\x08W4dqVPP\x05^\r\t\x18=" \
+ b'\xa0\x04\x1bC2RYQ6LDzbv9 v7?\x17\t:e%ewn"vj>fW\x1ch9^x2bz:6\x06[\x00' \
+ b'\xa0\x06eBO\x15\x15Gv1ZB\x17+%\x1c+aO\x1bPiyB~\x1abN+\rp\x1b>Y4pVHc;x\x1e)\x07:<' \
+ b'\xa0\tR\x11\x103Sh\r\r#[r22+"\x7f\'"Gf\x03?"2\x16_2\x08h"~\x04-0Tg{a\x07(8\x08JC' \
+ b'\xa0\x0c>^Y]V~b<-dF+,#+nN:\x03\x1e,bT;bg+!\x13K4z4\x7fSVUP\x05W~\t\x16C' \
+ b'\xa0\x04\x1bG1RYQRYDXqvW,vRP\x07uKe@n\x07\x054v{Jfk+hBHx?gz7*\x06[\x03' \
+ b'\xa0\x04eBO\x15\x15WJ2Z\\\x17+:\x08+i<\x1b\x1bXyR}\x1a_J+"k\x1bME4Z\\Hd9x".\x07;;' \
+ b'\xa0\tS\x11\x12pShG\x0c#\x03h2"\x10"r\x07"\x0f@\x03; "iH2\x1cI2\x0eP-\ryg\x17g\x07&3\x08KF' \
+ b'\xa0\x0c?ZY]V~^1-\x103+\x17\x18+mD:g\x0f,CV;0e+1\x11KB]4shVNW\x05Z\x7f\t\x17A' \
+ b'\xa0\x04\x1aG2RYQUYT&Wv(\x1bv>@\x07f3e\x0fLwV\x1eve4f_\x15h2}xKoz85\x06\\\x01' \
+ b'\xa0\x06vB_\x15\x15Gx=i\x11p*\x15y+hE\x1bVcyV`\x1aHN\x1blp\x1b1T4VgHo6x\x1f5\x07<;' \
+ b'\xa0\tS\x11\x02aSh5-#PL2!\x00"n\x00"DB\x03J\x05"hE2tJ"]T.\x0f\x08g&a\x07(9\x08LJ' \
+ b'\xa0\x0c?^YU^~X7-M)+O-+}T:\x19),g?;En+A*K.oD\riV?Q\x05[\x01\t\x16C' \
+ b'\xa0\x04\x1aG2RYQYXT\x18AvN*vHK\x07wCe2EwX,vuHfj\x1ehEexYsz60\x06[\x07' \
+ b'\xa0\x06gJo\x15\x15GaRYm{+?\x1e+xe\x1b{\x06yvu\x1aIl+9\x0b\x1b^f4lKHE8x$&\x07<<' \
+ b'\xa0\tR\x10\x02qSh#B#pe2\n\t"Kz";K\x03M#"HH2n;"qS-\x08ng\r[\x072*\x08MP' \
+ b'\xa0\x0c>ZIW^~\x15c-TE+ 8+bf:zR,Zy;5}+q.K+\tD\x12<V\x1aQ\x05_\x08\t\x16C' \
+ b'\xa0\x04\x1aG2RYQU{T\x0cJv\x1e\x15v)1\x071/e\x18AwC\x0cv&&fL\x0bh-vxavz8N\x06[\t' \
+ b'\xa0\x04$BO\x15\x15W\x0crj\x03\x05+U\x10;\rJ\x1b oyN}\x1alT+\x00y\x1bTS4d[Hg9x!1\x07<;' \
+ b'\xa0\tS\x10\x10`ShOG#Hm2H\r"|~"(@\x03v52\nJ2\x13@2\x15D.\x13\x0bg-]\x07/*\x08KJ' \
+ b'\xa0\x0c\x7f\x1e]U^~*--\x07;+b:+\x18n:\x13?-s\x02;\\\x05+?-KPoD\x1deVDR\x05W\n\t\x15A' \
+ b'\xa0\x04\nG6 YQt\\T\x135v\x03sv\x01\x15\x070\x07e8<v\x17ov/\x0cfK`i\x11%\x08\x08pz0>\x06\\\x06' \
+ b'\xa0\x06g\x02\x7f\x15\x15GE*YBv+0\x15+\x7fX\x1b:|z7\x0f\x1a\x16[\x1bj\x05\x1bLZ4iQHJ/x\x1e#\x07>5' \
+ b'\xa0\tB\x10\x02pSh\x1b5#ju2\x17~"Tr"(A\x03\x14E"@<2a92\x03W-\x10qg\x1fW\x070*\x08NT' \
+ b'\xa0\x0c~\x1e]W^~\x0e\x0b-ER+Y@+\x12x:3_-N";R\x16+UEKa\x1fD3,V\x1bQ\x05V\x02\t\x149' \
+ b'\xa0\x04\x1bG2BYQeADS7v\x0e\x06v\x1e-\x077!e/]w:\x05vK!fU\x00i%\x03xtzz74\x06\\\x01' \
+ b'\xa0\x06\'"O\x15\x15G~oYD{+\x1b\x0b;\x02L\x1b!gz\x1f\x13\x1aPS+\x01u\x1bEN4YmHy5x&\x18\x07>(' \
+ b'\xa0\rC\x10\x02`ShP\t#\x1aj2\x18q"\\e"*1\x03y>"p82\x7f62\x12;.\x01\x0bg9R\x07-+\x08NP' \
+ b'\xa0\x0c~\x1e]\x17^~\x00J-\\8+V<+\x0ft:&h-O\x16;Z\x1b+L_KT\x17D-!VrM\x05Q\x0f\t\x158' \
+ b"\xa0\x02CG6@YR \x02D\x7f\x16vl^ft\n\x07\r\x07e\x06\x14v\x03cv$\x0ef'bi\x10*xy{z,:\x06^\x02" \
+ b'\xa0\x02gJo\x15\x15Hz\x0fYT|+\x08\x16+vl\x1b,\x08y/p\x1a*V+\x0f\x13\x1b\x1fs4sQHP3x&\r\x07@(' \
+ b'\xa0\rY\x10\x12pShf\r$]\x00"w\x04"Sl"3+\x03p\x13"Z,2\x0022\x0bS-\x0b|g:R\x072*\x08NP' \
+ b'\xa0\x0c~\x1f_\x17V~\x04.-g]+W`+6\x04:Uh-n\x03;\n\x1c+peKm7D>\x0fVwL\x05Z\x7f\t\x156' \
+ b'\xa0\x06\nG6 XQ6fT63v\x02jv\x14\x05\x074\x05e9-v/mv:\x0efGfi\x0c\x1d\t\x16\x00z/A\x06^\x03' \
stream=io.BytesIO(b);
print("START DECODING")
while 1:
#remove marker
stream.read(1)
#decode 45byte data
try:
decode_data(stream.read(45))
except:
print("END DECODING")
file_object.close()
break;
