I'm trying to figure out how I can start the actual execution of a scenario after, for instance, 10 seconds of me pressing play.
I'm able to use "Timeout" and "Player Controller" boxes to pause/stop the scenario, but not for starting.
How can I make use of the "Play" option available in the dropdown list on the "Action to Perform" setting of the player controller box (image below)?
Any help or hints would be greatly appreciated!
Thanks in advance
Execute a scenario after a period of time
- play.png (7.69 KiB) Viewed 1900 times
Re: Execute a scenario after a period of time
Hi, that is not possible afaik. What you can do instead is to delay the event timeline by a number of seconds. Look at motor imagery tutorials for example. They typically start the Graz paradigm visualizations only after 30 secs.
