Hello, I was training a classifier and I was using a DSP box to manipulate the data, but the designer stops responding when it reach the end of the file. The main one that crashes it is the following: x == 0 ? 0 : log(abs(x)). Is there something wrong with the logic there or do I just have to update openvibe? If I have to update it, can I still analyze GDF files in openvibe 2.0.0?
I am using openvibe 1.3.0 on ubuntu 16.04 and I am using GDF files for the data. Also, the DSP in question is after the signal average box.
Openvibe 1.3.0 DSP crashing the designer
Re: Openvibe 1.3.0 DSP crashing the designer
Hi, thats odd. I can see two options,
1) pack the materials to a zip and upload somewhere so we can take a look.
2) run designer under gdb,
# openvibe-designer.sh --debug
gdb> run
and when it crashes, take the stack trace with 'bt' and copy paste it here, maybe it reveals something ...
(ps. moved the post to a better suited subforum)
J.
gdb> run
J.
