Simple dsp question
Simple dsp question
Hello, I have a question regarding the simple dsp box. I want to divide two signal averages to get the alpha/theta ratio and I am unsure how to do this. I have the two signal averages and have tried to assign each of them a variable via a simple dsp box and then divide the two using another simple dsp box but it has not worked. Any variable except for x throws an error. Thanks for your help.
- simpledsp question.JPG (24.28 KiB) Viewed 4095 times
